Cam swap
Old Jan 23, 2010 | 12:32 PM
wwardd's Avatar
Default Cam swap
Has anyone done a cam swap in a 5.3? I read u can swap a LQ9 cam in a 5.3 without having to reprogram the ecm. Said u end up with a 5.3 H.O. Crate engine. was wondering if anyone had issues doing this. Also said u can swap heads any thoughts on that. thanks
Old Jan 23, 2010 | 12:38 PM
RibeiroBJJ's Avatar
Praise The Lowered
using the search key would have given you ALL the answers to your q's, but I will do my best...
-The LQ9 cam is the same as a LS1 cam and is a direct fit into a 4.8 or 5.3...It will net you a little hp but way better off with a 212/530 cam if you want a "mild" cam imho..
-the LQ9 317 casting heads would lose power on a n/a 5.3 due to there larger combustion chamber(around 72cc vs 61cc approx) just get a perf valve job and mild port on your heads with that small of cam...
hope this helps
Old Jan 23, 2010 | 02:11 PM
Atomic's Avatar
I have a gauge for that
There are much better options than the LS1/LQ9 stock cam. I dont think anyone has swapped cams on these engines, you may be the first!
Old Jan 23, 2010 | 02:35 PM
BLUES MAN's Avatar
The House is Rockin'
exactly what i was thinking, why would you do a cam swap? these 5.3's are so powerful stock
if you really want to feel some seat of the pants difference in power, throw a tornado in there
Old Jan 23, 2010 | 04:33 PM
wwardd's Avatar
I am shooting for 350-400 HP.
Old Jan 23, 2010 | 05:36 PM
dirt track racer 81's Avatar
an lq9 cam is not going to net you 280 let alone 350-400, you might wanna do some more reading on guys that are in the 350 hp range
Old Jan 23, 2010 | 06:07 PM
Parke10's Avatar
Old Jan 23, 2010 | 07:36 PM
wwardd's Avatar
I am doing other mods also I had just heard that a Lq9 cam would give u 30HP.
Old Jan 23, 2010 | 07:44 PM
SLOXCAB's Avatar
what are your plans to get 350-400 horses?
Old Jan 23, 2010 | 07:55 PM
theres guys with much bigger cams and all bolts ons barely hitting 330-350. the lq9 cam is not going to cut it
