cam swap
Old Apr 13, 2009 | 05:06 PM
cwalker2006's Avatar
Default cam swap
i cant remember the name of it but that thing you screw into the spark plug hole to keep the valves up....what is it called and where can you get one at?
Old Apr 13, 2009 | 05:11 PM
00ChevyScott's Avatar
Wearin' da big hat
Oreilly's sells it. It's on the specialty tool isle.
Looks like this
Old Apr 13, 2009 | 06:11 PM
charcold-bowtie's Avatar
no silly. Just use half of a compression checker. I told you I have one bro. you have a text.....
Old Apr 13, 2009 | 07:45 PM
SUX2BU's Avatar
11.0 Moderator
I used to use that. But it takes too long. Now i just start at top dead center, use the firing order cut in half and use the pistons to keep the valves up.
firing order is 1-8-7-2-6-5-4-3.
1-8-7-2
6-5-4-3
At top dead center do cylinders 1&6, turn crank 1/4 turn then do 8&5, turn crank 1/4 turn then do 7&4 and turn crank 1/4 turn and do 2&3.
Old Apr 13, 2009 | 09:09 PM
budhayes3's Avatar
PT's Slowest Truck
That's what I use, just be sure to remove the shrader valve first
Old Apr 13, 2009 | 09:22 PM
sonoma43's Avatar
x2 thats what i use
OHsixLS3
Dec 27, 2016 09:30 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
Aboss
Jul 9, 2015 10:28 AM
GreyChevy
Jul 7, 2015 08:57 PM
