cam swap
Old Feb 28, 2006 | 09:27 PM
jus1975's Avatar
Default cam swap
How long did it take you guys to swap cams, rockers, rods and springs.
Old Feb 28, 2006 | 10:25 PM
v8
17,16,15,14,13,12,11 Drvr
can get it done in about 5hrs for cam,springs, and rods, never done the rockers so not for sure on that. good luck.
Old Mar 1, 2006 | 08:12 AM
jus1975's Avatar
I have the Flex fans on now. They allow alot more room. Do you have to remove the radiator or do you think its enough room. I haven't did any measurements.
Old Mar 1, 2006 | 08:15 AM
FILE's Avatar
Radiator needs to be removed.
Old Mar 1, 2006 | 10:53 AM
98TAauto's Avatar
yep, the radiator needs to come out but the ac condensor thingy is fine
the time consuming part is the springs. Normally takes about 40-60mins on the springs since you dont wanna rush to much their. Cam swap is simple... me and 2 friends swapped a cam out in a lil over a hour once, but each of us knew what we were doing so it was like cutting butter. But with a few people the average time is 3-6 hours roughly.. goodluck
Old Mar 1, 2006 | 11:22 AM
thunder550's Avatar
High on diesel fumes
My cam was done in 4 hours, the rockers and springs took me another 14 hours....damn adjustable rockers!
Old Mar 1, 2006 | 11:40 AM
ZR1 DREAMING's Avatar
Old Mar 1, 2006 | 12:42 PM
thunder550's Avatar
Originally Posted by Z06 DREAMING
Hahah I had no idea WTF I was doing....I'll blame the learning curve.
Old Mar 1, 2006 | 01:49 PM
white1's Avatar
Which time? my first took about 8 hours cause of the springs. The second, third and forth time I keep getting faster. A lot has to do with what kind of spring compressor you decide to use.
Old Mar 1, 2006 | 03:08 PM
jus1975's Avatar
I have the comp cam compressor. And I have the adapter to force air into the cylinders. How much air is need to keep the valves closed?
OHsixLS3
Dec 27, 2016 09:30 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
Aboss
Jul 9, 2015 10:28 AM
GreyChevy
Jul 7, 2015 08:57 PM
