Cam Specs...Feedback pls
14 Second Truck Club
Originally Posted by dhpro
Good street manners tho? Its my daily driver and I do more highway than anything else. That said I wanna crush a few Vettes & BM's around town too
. Hopw about stall recommendations? R/
Originally Posted by zippy
Considering that you're running a Radix, that cam will work rather well. With those heads the blower is likely to be too small rather than the cam.
Originally Posted by 02sierraz71_5.3
Looks like a good choice especailly for stock verter.
Id go with less aggressive lobes to limit overlap if you dont have it ground already or more aggressive lob and higher angles
Mag was on board with the head specs. They say I cuc run the Mp112 on these if I ramped up boost to 11-12psi, but above that heat becomes too big a prob. The Mp122 shud be more than enuf to handle this they say...if not, I guess we'll change 'em up!
On a 370 the MP112 would never achieve 11-12psi without being overspun to the point that it would only make good power in short bursts and that problem would only be worse with heads and cam. I am interested in seeing if the MP122 can do it on a well built setup like that. I am assuming it can also.
GXPJAY
Feb 13, 2022 08:15 AM
lawhitediamante
Aug 12, 2015 12:14 PM
