Cam Spec Suggestions
Old Aug 31, 2004 | 12:37 PM
redaddiction's Avatar
Default Cam Spec Suggestions
It is time to pick a cam I would like some opinions on what I should use
rcsb
3.43 rear gear
3200 stall
6.0
5.3 heads 2.02 1.57 valves
plus all bolt ons
Plans are for nitrous aroudn 150 - 175 shot
TIA
Marc
Old Aug 31, 2004 | 12:40 PM
Whoops forgot the heads are also milled .30 over
Old Aug 31, 2004 | 12:56 PM
BigKID's Avatar
Wow.. .030 milled 5.3 heads on a 6.0.. that is going to be some wicked compression.
Anyway... since p-v clearance is more than likely going to be a problem with big duration/lift numbers.. I would say in the neighborhood of a high 22x low 23x with a .57x-.58x lift. Just choose an agressive lobe profile to get the most out of it.
Old Aug 31, 2004 | 01:05 PM
Sport Side's Avatar
Try out the fms cams. He can build one somewhat around your setup. Theres also some guys out there who can really go custom for you, and get the specs just about perfect.
Theres also a bunch of off the shelf cams. Better to talk to the experts though if your puttin together an expensive setup.
JordanH
Aug 8, 2015 07:59 PM
OLD BULL
Aug 1, 2015 05:00 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
NuckenFuts
Jul 9, 2015 08:45 AM
