Cam selection
Old May 25, 2008 | 03:19 PM
RandomHero's Avatar
Originally Posted by NoChrome
valve overlap causes lope not the "size" of the cam
You're both right. Duration and lobe separation angle are the two major factors in calculating overlap. In short though I higher duration cam(230/230) will generally "lope" harder than a (212/212) because generally most cams have a lobe separation angle between 110-118
1989k1500's Avatar
He needs gears before a cam.
Old May 25, 2008 | 04:13 PM
viciousknid's Avatar
Where's the Beef?
Sounds like a custom grind 216/220 112°. I have a 216/220 114° and it feels good even without a tune. But like K1500 said, He should get gears too.
Old May 25, 2008 | 05:15 PM
nonecktribe's Avatar
if he is running that size tire...he needs to go with a smaller cam i.e. 216/220 or 212/218 or else hes gonna have to run a huge stall which in turn will cause tranny to heat up...which aint good
Old May 25, 2008 | 05:38 PM
RandomHero's Avatar
That second part makes no sense chief. Plenty of people run big stalls with big tires. That's not to say he won't have other issues, but a $50 transmission cooler will solve the heat problem.
Old May 25, 2008 | 07:24 PM
Heath's Avatar
I agree with most all of this, but your missing the point. Hes not wanting the cam to make his truck faster, he just wants a lopey idle.
Old May 26, 2008 | 08:28 PM
Where's the Beef?
which is why we are telling you which cam's to choose from.
stock48
11
Aug 18, 2015 05:55 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
