Cam selection
You're both right. Duration and lobe separation angle are the two major factors in calculating overlap. In short though I higher duration cam(230/230) will generally "lope" harder than a (212/212) because generally most cams have a lobe separation angle between 110-118
That second part makes no sense chief. Plenty of people run big stalls with big tires. That's not to say he won't have other issues, but a $50 transmission cooler will solve the heat problem.
lawhitediamante
Aug 12, 2015 12:14 PM
