cam question need help !
Old Aug 22, 2009 | 11:45 PM
erick04's Avatar
Registered User
Default cam question need help !
would this cam work good on a 2004 silverado with a n/a 4.8 with longtubes intake exhaust and pulley its a ligenfelter gt2-3 camshaft duration @.050 207/220 - 571/578 lift 118lsa and what supporting mods would i need if it would work good ...for example springs and rods etc...
Old Aug 23, 2009 | 01:07 AM
00Silv4.8's Avatar
LS6 springs and hardened 7.4" pushrods. probly wont need a stall but it wouldnt hurt
Old Aug 23, 2009 | 07:30 AM
erick04's Avatar
Registered User
cool thanks 00silv4.8 ...
Old Aug 23, 2009 | 07:52 AM
SweetS10V8's Avatar
Id go with 918 springs and hardened pushrods myself.
Old Aug 23, 2009 | 09:05 AM
erick04's Avatar
Registered User
ok but is this cam goin to work good for my 4.8 naturally aspirated?
Old Aug 23, 2009 | 09:19 AM
00ChevyScott's Avatar
Wearin' da big hat
Not really. It's an F/I cam. Why are you set on that cam instead of something that really fits your needs?
Old Aug 23, 2009 | 09:27 AM
erick04's Avatar
Registered User
not set on that cam but its a good deal for 200 dollars thats why im asking. i had my suspicions that it was a forced induction cam cause of the split on it...but what cam would be good for my truck im goin to eventually spray a 100 shot down the road?? thanks for the help!
Old Aug 23, 2009 | 09:42 AM
Wearin' da big hat
Don't buy a cam because it's cheap, that's definitely going at it the wrong way. I would look into a standard N/A cam for your truck, since you won't be spraying any huge shots (300+) and it's a street truck.
And it all depends on what you want to do with your truck. Are you wanting to run an aftermarket stall, and if so what stall speed would you want. Also, what rear end gears do you have? Is your truck an extended cab or regular cab? What is your budget for the cam swap and everything else you need to go with it.
Old Aug 23, 2009 | 09:59 AM
erick04's Avatar
Registered User
its a 2004 singlecab stepside 4.8 ..mods are tune by file no cats dynatech longtube headers bbk cai e-fans corvette servo and spacer my best without the headers was 15.0 in some really hot muggy weather ..got the headers installed just waiting to get my pulley and then gettin a wideband retune..and some 3.73 also as far as stall goes dont want to sacrifice driveability, so the highest i would go on a stall is 3k..i have a 5.3 in the garage thats goin in by december so a cam that will also work well with the 5.3
Old Aug 23, 2009 | 10:17 AM
Wearin' da big hat
I think you'd like a TR220 112lsa. A lot of people run that cam with killer results.
