Cam question
Old Oct 9, 2007 | 10:11 PM
03 BLACKOUTSSS's Avatar
Default Cam question
I am looking at two vinci cams.
The 043 model:
DUR @ .050" 210*/ 218*
LIFT .531/.531
OVERLAP 48*
LSA 114*
Description - POWER RANGE 1700 TO 6000
PROVIDES HIGH TORQUE, MODERATE LIFT, LONG VALVE SPRING LIFE
LIGHT CHOPPY IDLE
and the 112 (new) model:
DUR @ .050" 210*/218*
LIFT .551 / .551
OVERLAP 50*
LSA 114*
PROVIDES VERY HIGH TORQUE GAINS
GOOD THROTTLE RESPONSE - LOADS OF "TORQUE" - HIGH LIFT
LIGHT CHOPPY IDLE
Notice that the only things that vary are the overlap and the lift. Are there any SOTP differences (significant) between these cams? I guess what I am saying is is the 112 model enough of a bigger cam to warrant choosing it over the 043 model?
And a more important question is better for Transmission life?
Old Oct 11, 2007 | 04:12 PM
anyone? I know that they are small cams, but some insight would be appreciated.
Old Oct 12, 2007 | 11:16 AM
UnrthdxDream's Avatar
those cams shouldn't affect transmission life any differently. they are both and increase in power and will have your trans take one more step towards the grave.. get a little bigger stall and a big trans oil cooler and you should be ok.
Old Oct 13, 2007 | 09:52 AM
How does a higher stall HELP tranny life? I kinda figured that doing that would push it futher toward the grave.
Old Oct 13, 2007 | 09:55 AM
bluecajun5.3's Avatar
11 Second Truck Club
blackout, the second one sounds like a good cam.
a higher stall will reduce tranny life.
Old Oct 13, 2007 | 10:23 AM
kw05silverado's Avatar
yea u kinda need a stall when u put in a cam. i would say new tranny first then cam.
Old Oct 13, 2007 | 02:22 PM
I am really trying to convince myself that I DON'T need a new tranny. I think that I am gonna go with the first cam. Its got lower lift, but I can use LS6 springs, and its not a brutal cam, I think I'll be able to get away with it. I don't drive the truck nearly as much as I used to (I travel alot for work), so I think the stock TC and tranny should survive for a good while. I already have the biggest universal tranny cooler that NAPA makes, so I think I should be okay...am I lying to myself?
Old Oct 13, 2007 | 04:12 PM
ap2002's Avatar
LS6 springs are good to about .570 lift, the LS6 cam has a .551 aswell so I wouldnt hesitate to get the second cam for the extra power, and if possible I would get it on a 112LSA...
Old Oct 13, 2007 | 06:03 PM
How does the LSA affect the powerband and driveability of the cam. I have read several stickies on it, I just can't retain it all that well.
Old Oct 13, 2007 | 06:29 PM
ramdaspadhye's Avatar
The lower the lsa, the quicker the power/torque comes in...
Also, higher LSA's work better for forced induction. If you're going NA, go wtih a 114 or 112lsa. The lower the LSA, the choppier the idle, and the more power down low you have.
Also look at the Comp Cams 212/218. It's a nice all around cam for anything from a RCSB to a Yukon/Tahoe/Suburban. I would suggest getting a stall regardless. You'll like it
