Cam Question??
Old Nov 16, 2004 | 07:40 AM
01Blackerado's Avatar
Default Cam Question??
Has anyone notice any loss in low end when switching from a stock 5.3 cam into a SS silverado cam/Ls1 cam... I just want to know what to expect when I waist time doing this project.
Old Nov 16, 2004 | 08:36 AM
FILE's Avatar
You would not loose any low end. There is not much of a difference between them.
Old Nov 16, 2004 | 03:42 PM
MrDestinE's Avatar
well... got here somehow or another...... WTF....
Old Nov 17, 2004 | 07:40 AM
The reason i asked is cause, ...well...i think im right, when i say that the LSA being a higher number instead 114 its 116 and i thought that meant my power band starts a little higher than it does on the 114 but i could be way off im really more or less just guessing.
Old Nov 17, 2004 | 09:07 AM
Mr. Sandog's Avatar
Larger LSA means a wider powerband with less peak, it does not move it anywhere. Larger duration moves the powerband up the RPM scale. So, for example, if you have two 212/218 cams, one on a 114 LSA and one on a 116 LSA, the 114 LSA cam would have slightly more peak power and a slightly narrower powerband, while the 116 LSA cam would have a slightly wider powerband with slightly less peak power.
Old Nov 17, 2004 | 01:56 PM
Nice, thanks so i should be fine with this mild of a cam and maybe even notice a slight gain in performance without any loss!!?? Along with this cam i installing the 7.4" p rods, roller tip rockers, and the cam, and of course re-nelson it!
Old Nov 17, 2004 | 02:05 PM
Mr. Sandog's Avatar
So you're swapping out a 190/191, .457/.466, 114 LM7 cam for a 196/207, .467/.479, 116 LQ9 cam, is that correct? Are you planning new springs?
Is the cam free? You should see a little improvement, but not that much. You sure you want to do that much work for just a little gain?
You won't have any loss down low....with a 5.3L you're good up to 206/212 or so.
Old Nov 17, 2004 | 03:15 PM
Nice thanks, yeah thats exactly what the swap is.Im getting new springs...the cam was basically free i payed shipping really... and the springs are from the z06<--- are these going to be too much spring for the cam,even with the new p rods?!
Old Nov 17, 2004 | 06:43 PM
Mr. Sandog's Avatar
Z06 springs will be fine with that cam. Keep us posted as to how it goes!
Old Nov 18, 2004 | 07:55 AM
will do thanks for all your help
Denali08
Aug 9, 2015 04:34 PM
Jake75
Aug 5, 2015 01:26 PM
USMCvet0311
Aug 1, 2015 07:45 AM
bbowerman
Jul 26, 2015 10:57 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
