cam question
Old Jul 12, 2004 | 05:08 PM
02 SilveRado's Avatar
Default cam question
is there any cam that you can use with your stock springs or push rods or rockers, would it even be worth putting in if you did it that way or should u just go all out?
Old Jul 13, 2004 | 11:15 PM
U LUZ's Avatar
you better change the springs ....they suck in the trucks.....buy some used ls6 springs if you are on a budget...they are good to .550 lift which is all you need for a truck cam......
Old Jul 14, 2004 | 08:22 AM
marc_w's Avatar
Crane makes some lower duration tow/economy cams that I believe can be used with stock springs. Lift is right around .5" Durations are low, under 210* I beleive.
Old Jul 14, 2004 | 09:07 AM
mudz5.3's Avatar
I am pretty sure max lift on the stock 5.3/4.8 springs is .500. You could get a 00 Z28 cam and it will work with the stock springs. Any higher than that, say Z06 cam you would need atleast the ZO6 springs as well.
Denali08
Aug 9, 2015 04:34 PM
Jake75
Aug 5, 2015 01:26 PM
USMCvet0311
Aug 1, 2015 07:45 AM
bbowerman
Jul 26, 2015 10:57 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
