Cam is in. Need some help.
Old Jul 12, 2004 | 12:24 PM
Default Cam is in. Need some help.
I installed my cam last week, and it sounds sweet. I got idle set but when i put it in gear with the brake on it wants to die. Is this a vacume problem? It keeps idling fine ingear w/ the e brake on, just not with the brakes on.
It pulls crazy hard now, and i cant wait to get some new times. I have a few more questions that i'll post up later.
Old Jul 12, 2004 | 12:45 PM
Sport Side's Avatar
is this the lingenfelter cam or a new one? what specs?
Old Jul 12, 2004 | 01:42 PM
Lingenfelter 218/229 .560 113LSA.
It lopes hard enough to rock the truck side to side at idle, and it revs fast too. Im just not sure if i need to put a vacume booster on for the power brakes. I really like the way its running, and think it will drop my time alot. I am currently shifting it at 6300rpms and it just keeps pulling harder and harder the higher i rev it. Down low it feels about like stock, but up high it feels like its pulling as hard as my Camaro.
By the way, i used the russian rulet method on the cam swap and it went perfectly. I wouldnt reccomend it though.
Anyone else with fairly large cams have trouble idleing in gear with the brakes on?
Old Jul 12, 2004 | 01:53 PM
mudz5.3's Avatar
Did you drill the throttle body? I would start at a 1/8" but you will probably have to go larger. Just drill a hole at the bottom of the plate. The reason being that it idles ok with the brakes not on is the engine is using the vacuum in the booster to let it idle. When you apply the brakes you are taking that air supply away. Good luck.
edit: Just realized you weren't a noob, sorry, but I'll leave it up for others I guess.
Old Jul 12, 2004 | 01:57 PM
Sport Side's Avatar
I found this the other day while i was doing some reading. check it out before you go drilling your TB,
https://ls1tech.com/forums/showthrea...ighlight=drill
Old Jul 12, 2004 | 05:00 PM
Stroker 1500's Avatar
i want videos!!!!!
Old Jul 14, 2004 | 06:13 AM
Originally Posted by rcfast
i want videos!!!!!
I have some idle video i will try to post up soon.
Once i get internet at home again i will have track and burnout videos to post up also.
Still need to know if my vacume problem is common, and if i need to put a vacume booster on the power brakes to stop it. BigTex, Parish what do you guys think?
I cant seem to find a place to refill my bottle here in Maine, but i should have some new N/A times comeing soon.
Old Jul 14, 2004 | 09:05 AM
mudz5.3's Avatar
If you don't have a hole in the tbody already, meaning you went from stock to this cam, then yes you do need the hole, or the mod listed above.
Old Jul 14, 2004 | 09:48 AM
Flyer's Avatar
I don't have a hole in my TB, but your cam is a little bigger than mine. You should be able to tune some of it out if not all of it. Have you done anything with the diel air control tables yet? There are 2 of them.
Old Jul 14, 2004 | 10:53 AM
CARAZYCUTER 4.8's Avatar
In your edit file you can tune idle for in gear a/c on or a/c off You can also change some paremeters of the IAC if you choose not to drill your throttle body. There is also timing advance you can add as well.
