cam/pushrod combo question
Old Jan 9, 2008 | 05:43 PM
  #21
RotaryResurrection's Avatar
For anyone reading out there, I have a question about calculating the length of the pushrods I'll need. I bought the comp cams length checker. Based on the above conversation we have a good idea of what length I will use.
However, I am installing new lifters, cam, etc. The lifters have some movement (preload) in them when the valvetrain is fully installed, if I understand correctly. IF using a pushrod length checker on a new set of lifters, how will the preload be accounted for in the length measurement? Or, put another way, how much does the lifter compress in a stock application, and should I add this amount of preload onto the measurement I take with my checker when ordering?
Old Jan 15, 2008 | 08:07 PM
  #22
Tootall's Avatar
that's a ton of material that's been ground off . . . you're looking at a rebuild, or new bearings at least
andrewlong
Nov 9, 2016 09:38 AM
Forcefed81
Sep 8, 2015 10:02 PM
bisqikss
Sep 8, 2015 03:35 AM
2004gibbstruck
Sep 7, 2015 06:05 PM
iregret
Sep 7, 2015 01:20 PM
