cam purchase assistance needed
Old Oct 5, 2013 | 01:30 PM
justoyz2's Avatar
Default cam purchase assistance needed
ALL,
I am looking to beefing up my 5.3 engine. I am looking at one of these cam combo kits. Please help me determine which kit is the best bang for the buck. This will be in a GMC Typhoon, the heads will be stock.
I would like to know what HP gains could be achieved with these kits, and if the prices are good for the product I am getting. Thanks in advance
COA1
-54-450-11 CAMSHAFT (271124476224 $1069.88)
cam specs .513/.520@115 LSA
-850-16 OE STYLE HYDRAULIC ROLLER LIFTERS
-3158KT Timing Chain Set
-26915-16 Valve Springs
-774-16 Retainers
-623-16 Valve Locks
-511-16 Valve Seals
-4705-16 Spring I.D. Locators
-7638-16 Magnum Pushrods
-Instructions
-Assembly Lube
COA2
-54-451-11 CAMSHAFT (300875545672 $1069.88)
cam spec .554/.558@115 LSA
-774-16 Retainers
-623-16 Valve Locks
-511-16 Valve Seals
-Instructions
-Assembly Lube
COA 3
-54-458-11 CAMSHAFT (390393412408 $1069.88)
cam spec .614/.621@113 LSA
-774-16 Retainers
-623-16 Valve Locks
-511-16 Valve Seals
-Instructions
-Assembly Lube
Old Oct 5, 2013 | 10:05 PM
batboy's Avatar
11 Second Club
You didn't list duration. The first two listed are baby cams and then you throw in a bigger one.
These two would be my pick, the 212/218 low lift or high lift, if this is a street driven daily driver.
54-412-11 - XFI RPM Hydraulic Roller Camshafts
54-424-11 - XFI RPM High Lift Hydraulic Roller Camshafts
Old Oct 6, 2013 | 05:07 AM
justoyz2's Avatar
It will be a street rode with highway use, occasional track or street racing
Old Oct 6, 2013 | 05:14 AM
justoyz2's Avatar
Here are the durations
208/212 on cam 451-11
206/212 on cam 450-11
227/253 on cam 458-11
Old Oct 6, 2013 | 09:48 AM
Chevy_King1500's Avatar
220/220 for that small of a truck, maybe a little bigger
Old Oct 6, 2013 | 09:55 AM
03sierraslt's Avatar
Well you should forget about the last one.
Old Oct 6, 2013 | 11:37 AM
batboy's Avatar
11 Second Club
I agree, throw the last one out. I would throw the first two out too and go a little bigger. It depends on your goals and whether you plan on getting a higher stall converter. The two cams I listed are about as big as you can get and still keep the stock converter. If you get the Comp Cams low lift, then you can use cheaper LS6 springs. If you want a bit more lope at idle (lower LSA), definitely look at the SDPC HT1 truck cam (214/218 .559/.562 111).
Old Oct 6, 2013 | 10:06 PM
justoyz2's Avatar
I am okay with installing a newt tq-converter. I want a radical sound and good performance, with the ability to drive from Memphis to Tampa
Old Oct 7, 2013 | 02:32 PM
Trizney's Avatar
You keeping the LS Typhoon AWD?
Old Oct 7, 2013 | 03:46 PM
Whitecrewcab's Avatar
If you want the sound with decent performance, look at the Thumpr cams.
