View Poll Results: Witch cam would you want to use.
Lunati 60510
75.00%
GM Hot Cam
25.00%
Voters: 4. You may not vote on this poll
Cam Options?
Old Aug 25, 2010 | 09:31 PM
Jermoslin's Avatar
Default Cam Options?
I know this is done over and over again, but if you were to use one, witch would it be. Based on cams only, dd, LS1 stock block, 862 stock heads. I know there are better cams. Wondering if the more duration with the stock heads would be better or the shorter and a little more lift. The Lunati has a ramp rate of 50 if anyone wanted to know.
Lunati 60510 212/218 .531/.531 113
Hot cam 217/228 .525/.525 112
Old Aug 25, 2010 | 10:32 PM
brent5631's Avatar
I know the lunati cam and the many other variants are very well liked. I dont have any experience with either but from what I've heard the 212/218 is a very nice cam.
But the main question is what are your goals for the truck?
Old Aug 26, 2010 | 12:41 AM
Mangled03gmc's Avatar
Baltimore Whore
Welp they are not the best grinds but out of the 2 I would use the lunati.. What stall you plan to use, ect??? It plays a good role as in cam choice you go with
Old Aug 26, 2010 | 11:53 AM
Jermoslin's Avatar
The TB that in mine sig. I'm just swapping in a rebuilt stock short block LS1 and using everything else on the truck. The lunati is in my truck but I can get the hot cam from my boss at work. I was just thinking it the truck had more duration it mite act like I had better flowing heads. I don't think the power will be that much different from to two and the lunati will give me more torque witch I want. Not spinning the truck past 6k anyways. Any thoughts will be nice. To all- please vote anyway.
Old Aug 26, 2010 | 11:57 AM
budhayes3's Avatar
PT's Slowest Truck
The GM Hot Cam is known to have lazy lobes and is therefore hard to tune and not a great performer. Of the two, I'd stick with the Lunati.
Old Aug 26, 2010 | 11:58 AM
Jermoslin's Avatar
I think I will too
Oobray
Jun 13, 2022 03:38 AM
ARC
57
Feb 21, 2022 10:54 AM
oharajo
Jul 18, 2015 09:24 PM
04BlackGmc
Jul 16, 2015 04:10 PM
