Cam only record ...
#71
To be honest, I think I'm actually running LS6 springs on my truck. I think I have a set of 918's floating around somewhere that got lost in a mixup of me moving 3 times and some other things. This would be a huge contribution to the valve float at 6200.
I try not to get it over 3500 when it's cold ... I konw that helps prolong the life of the spring.
Dunno on the 60e. I've got way to many things on my plate to be doing to much with the truck right now, but I'd really like the gas mileage out of the 60e too.
Heads are STOCK, cept for the valve springs. The motor is stock too, cept for the rod bolts I put in last weekend.
#77
Banned
FLYER WITH THAT CAM I WOULD NOT RUN 918 U WILL STILL GET SOME VALVE FLOAT
SENICE U HAVE OVER 600 LIFT.I WOULD GET SOME DAUL SPRINGS.THEN U MAY BE ABLE TO TURN IT 7200 R 7400 TILL THE LIFTERS START COLASTING.BUT YOU PUT SOME 5.13 GEARS WITH A 30 RADIAL SLICK AND @ LEAST A 4K FLASHING VERTER U COULD GET SOME GOOD 11.s
AND I DON'T HAVE THE SOILD LIFTERS R THE 1.85 ROCKERS ON THE 5.3I PUT THAT ON THE 6.0 AND I HAD A LITTLE SMALLER VERTTER
