Cam only record ...
Old Nov 4, 2005 | 07:37 PM
  #61
Flyer's Avatar
233/239 598/603 113.
Sound clip in sig
Old Nov 4, 2005 | 07:39 PM
  #62
Fogle07's Avatar
wow thats a huge cam. who makes it? also how is the rpm range with it and what stall. thanks
Old Nov 4, 2005 | 07:40 PM
  #63
Flyer's Avatar
It's a custom grind from TSP.
It comes on strong, real strong, at 4500. I have a 3000 on an 80e.
Old Nov 4, 2005 | 07:54 PM
  #64
Fogle07's Avatar
so how would this do with a 60e and a 3000? im going to see if this comp will let me listen to it. i hate dialup
Old Nov 4, 2005 | 08:25 PM
  #65
Flyer's Avatar
It would be a lot better. You better have someone ready to tune it in person though, cause it's a bitch to get dialed in. Part throttle tuning is the easy part, it's the idle and just off idle that's the trouble.
Gears will help too.
Old Nov 4, 2005 | 08:41 PM
  #66
v8
17,16,15,14,13,12,11 Drvr
hey flyer when is the 60e going in? are your heads on the 5.3 still stock or minor adjustments been done to them? When is the next time for the track for ya?
Old Nov 4, 2005 | 08:47 PM
  #67
Fogle07's Avatar
also do you have to have some different springs than 918's or will those work with that big of a cam?
Old Nov 4, 2005 | 08:49 PM
  #68
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Coil bind on 918s is .600 lift you should be fine with them.
Im going to run .595 lift on my 918s till I get my DART heads in.
Old Nov 4, 2005 | 08:58 PM
  #69
Fogle07's Avatar
how long will the springs last with that big of a cam?
Old Nov 4, 2005 | 09:04 PM
  #70
1slow01Z71's Avatar
Anybodies guess man depends on how much you drive, how hard you drive it and all that. Some poeple have 918s that have been on their truck for 70,000 miles and not have a problem but with the higher lift I would think it would accelerate the demise of the springs but how much I dont know. You could always pull one off every once in a while and put it on a spring tester.
