Which Cam for my mods ???
Old Feb 19, 2015 | 03:43 PM
kelobro's Avatar
Also, the hi-flow TPI intake (or GM TPI intake) would give you more off the line torque at the expense of 5500+ RPM horsepower. If it's a street truck, you'll enjoy the low end torque more and you could make a few bucks pulling stumps for people.
Old Feb 20, 2015 | 09:12 AM
97ChevyVortec's Avatar
Originally Posted by gamble686
I would contact someone local if possible. Where do you live?
I live in Groves Texas 77619
Old Feb 20, 2015 | 09:14 AM
Originally Posted by kelobro
For Gen I truck engines, I liked the comp cams 260HR. You wouldn't want to go too much bigger for a truck with stock stall converter. Check out cam selections for comp cams at CamQuest ? Select The Perfect Camshaft & Valve Train Components. Put in your specs and performance choices and see what they offer.
I do plan on putting at least a 2500-2800 stall in
Old Feb 20, 2015 | 09:22 AM
I've been waiting to hear alittle feed back on that intake but most threads die off before anything comes back.. its gonna be a everyday driver/street truck...
Thanks guys for all the info... I've been into atv's and sxs's for so long gotta get back into my trucks...lol
Old Feb 21, 2015 | 10:14 PM
kelobro's Avatar
Keep in mind the tunnel rams are designed to maximize horsepower, almost always at or above 5000 RPM. The GM TPI intake was originally designed to bestow torque upon the gutless 305 engine. Once GM decided to put 350s in cars again, they stuck with the TPI intake because they knew the extra low end torque would make buyers smile during the test drives. Their greatest problem is that they tend to max out too early with too much air restriction above 5000 RPM
Stock TPI 350 dyno sheet:
http://www.mentalsocket.com/Iroc87/irocdyno2.jpg
With the right cam, 400+ Ft/lbs of torque early in the power curve should be easy. A good cam would also help to flatten out the power curve
Old Feb 21, 2015 | 10:32 PM
kelobro's Avatar
Comp Cams 252 XFI HR13 grind with a GM tuned port injection (TPI) will get you over 420 ft/lbs of torque at 2500 RPM. That is the definition of a hard pulling truck motor in my humble opinion.
Play with the options at CamQuest ? Select The Perfect Camshaft & Valve Train Components and see what makes you smile.
Old Feb 23, 2015 | 03:58 PM
great info there
Old Feb 23, 2015 | 03:59 PM
What springs would you run? I hear alot of people talk about beehive's
Old Feb 23, 2015 | 09:17 PM
What do you think about the 260xfi Hr13 ?
Old Feb 24, 2015 | 03:12 AM
gamble686's Avatar
For the money you will end up spending any reason not to do a swap to something more straight forward?
As for the 411 swap your best bet is to drive to Houston.
