Cam Install Soon
Old Oct 15, 2004 | 04:51 PM
Deckhand's Avatar
Default Cam Install Soon
Hey guys this week I might tackle my cam installation. Ive bought the SDPC gasket kit that also includes the crank bolt. Is there any suggestions or insight that would make things easier? Do I have to mess with any of my A/C stuff? Thanks.
Old Oct 15, 2004 | 04:57 PM
Sport Side's Avatar
, but what cam did you go with?
Old Oct 15, 2004 | 05:06 PM
one03sierra's Avatar
Formerly one92rs
Talking
nope you will need a puller for the crank pulley. you do not need to mess with the a/c. remove the radaiater and get after it.
Old Oct 15, 2004 | 08:25 PM
budhayes3's Avatar
PT's Slowest Truck
It's a piece of cake IMO. Just make sure the lifters stay up (JPR Tool from Thunder worked great for me), and if you're doing springs, make sure you have a good spring compressor. I've heard great things about the Crane unit, but used the one from Thunder myself.
Here's a link that will definitely help: http://www.ls1howto.com/index.php?ar...7d64e0529a4f06
It refers to an F-body, but the bulk of it applies to trucks also.
Have fun!
Old Oct 15, 2004 | 08:37 PM
marc_w's Avatar
I left my radiator in, for what it's worth. Just moved it up and supported it with random household objects.
When you remove the cam with the longer water-pump bolts in, remove them when you can get a good grip on the cam.... otherwise they'll hit the condensor and stop you just short of getting the cam out.
Other than that, not much. I had a good time doing my internal work. I'd prefer it anyday over working with axles and suspension and what-not.
Old Oct 15, 2004 | 08:49 PM
get a longer crank bolt to help get the pulley back on,saves some fooling around
Old Oct 15, 2004 | 09:14 PM
Kano's Avatar
whats the part # for that gasket kit
Im getting ready for the same thing
Old Oct 15, 2004 | 09:19 PM
Kano's Avatar
is this correct?
(KITSD51902 Cam Install Gasket Kit, 1999-03 LS1/LS6)
Old Oct 15, 2004 | 11:16 PM
ThunderZ28's Avatar
12 Second Club
Good deal man
get after it
Old Oct 16, 2004 | 01:18 AM
Deckhand's Avatar
Originally Posted by 01 Thunder
