Cam Install Soon
Originally Posted by Deckhand
Hey guys this week I might tackle my cam installation. Ive bought the SDPC gasket kit that also includes the crank bolt. Is there any suggestions or insight that would make things easier? Do I have to mess with any of my A/C stuff? Thanks.
Make sure oil pump o ring seats properly, get a new one of those also. I think you will have to take off oil pump to get bottom crank pulley off. I would get a new timing chain as well. The stock single row chains stretch a lot.
damon
Originally Posted by vanillagorilla
He'll have no problem tuning it.
Hotcam: It's like bangin' fat women...don't knock it until you've tried it.
hey, did you replace the valve seals and install the valve seats that come with the kit as well?
There ARE more radical cams out there, but this is a 4.8 were talking here. Plus theres not many cams out there with a 228+ exhaust duration that keep the lift low. Our heads simply do not flow for **** above .540". 1.89"intake vavles and 1.55" exhaust valves don't cut it. If you plan on doing heads, then go for some high lift cam, more power to you. F-body guys continually make over 400rwhp with this cam, with a torque curve as flat as Nebraska. Its about area under the curve not peak #'s. Sure a TR224 might, and I say might, give you higher peak #'s, but the area under the curve will be a lot different. Plus Deckhand is spraying, and if you do a quick search here, you will see that this cam LOVES the juice! Just prepare yourself for a new fastest 4.8.
Deckhand, I did use the seats and seals. The seats are a different thickness than the stockers (about .040" I think) providing the proper installed height. Go get 'em!
