cam install question
Old Nov 19, 2006 | 11:35 AM
Default cam install question
Im trying to install a cam in my 99 Silverado w/ 4.8L and cannot find the two holes to slide the rods in that hold up the lifters. I did a cam swap on my ls1 and this is not the same for some reason. Any help would be appreciated.
David
Old Nov 19, 2006 | 12:31 PM
benvortec's Avatar
I just did a cam swap on my 6.0l and I used the pen magnet method, and it worked perfectly. LS1howto.com has the rod method like you were talking about doing on your Camaro. Check out that website if you need help.
Old Nov 19, 2006 | 12:41 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
They are exactly where they were on your LS1 I promise. It will be those holes on both side of the cam passageway. If all else fails put the pushrods in spin the cam a few times and see if they fall down. If they dont pull the pushrods and spin the cam a few more times pull it and put the new one in.
Old Nov 20, 2006 | 08:16 PM
Question
Where do you get these pen magnets?? My local auto parts stores only have the magnet pen that is just a sole antannee looking pen.
I was told the ones needed have a clip to hold them up. Anyone sell them as a set of 16? Where do I get that many of them if not?
Jim
Old Nov 20, 2006 | 10:26 PM
desTRUCKtive's Avatar
The ones that look like an antenna will work.
Old Nov 20, 2006 | 10:31 PM
dirt track racer 81's Avatar
the holes are there..you did take the retainer plate off didnt you..
Old Nov 20, 2006 | 10:52 PM
I bet we just found the culprit.
Old Nov 21, 2006 | 04:24 PM
benvortec's Avatar
Jim
The pen magnets do look like an antenna. They do also have a clip, but they would work either way. I bought 16 at Orliely's for like $60 and then took them back and got my money back when I was done!
Old Nov 21, 2006 | 06:47 PM
Talking
Cheap A$$!!!!!!!!!!!!
Jim
Old Nov 21, 2006 | 09:01 PM
5/16's wooden dowl rod is the cheepest
The_W
Oct 28, 2015 09:00 PM
all_individual
Oct 10, 2015 10:09 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
all_individual
Jul 13, 2015 11:01 AM
