cam and headers???
Old Jan 15, 2010 | 12:02 AM
  #21
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by 00ChevyScott
Lol I would LOVEEEEEEEEEEEEEEE to see a diablowsport tune for that cam
Old Jan 15, 2010 | 01:27 AM
  #22
chubbz817's Avatar
So what can i expect my gains to be?? and where can i get
this cam and for hw much???
Old Jan 15, 2010 | 11:10 AM
  #23
grey matter 04's Avatar
13 Second Truck Club
no cats K&N intake and a magnflow muffler with a tune i ran 15.1 at 93mph
Added just the 212/218 cam and touched up the tune 14.7 at 97.7mph
This is with a 2.4 60ft best it would cut.
Its got the mph for high 13s just got to make it leave,reason i have a stall now
Its a good lil cam
Old Jan 15, 2010 | 12:56 PM
  #24
budhayes3's Avatar
PT's Slowest Truck
Do you mean the Comp 212/218? Check some of our sponsors to the right, such as Texas Speed, possibly SDPC, and if they don't have that particular grind, google Comp Cams and shop around. You could check the classifieds here also, as mentioned it's a very popular cam. As mentioned, you should see substantial gains, my baby cam with tuning dropped me from 16.5@81.7mph to 15.6@89.5mph (runnin on 33's in full street trim, minus the spare on the faster run)
Search this section for 212/218 and you should find plenty of results. There was one thread in particular that had dyno results from this cam, on 87 octane I believe and the numbers were excellent
*EDIT* Here's NicD's thread with the dyno graph: https://www.performancetrucks.net/fo...ight=212%2F218
sometimes less is more
Old Jan 15, 2010 | 01:43 PM
  #25
chubbz817's Avatar
Whats the biggest cam i can run with the stock verter an thanks for info too
Old Jan 15, 2010 | 02:32 PM
  #26
budhayes3's Avatar
PT's Slowest Truck
Me, I'd only go as big as the 212/218 with the stock converter if you still want some low end torque, and honestly I'd personally throw a mild converter in there. Even my baby cam would benefit from a mild converter, even though it's not necessary. I'd think that stepping up to say a 216/220ish you'd at least want a 2600 converter to make the most of it.
Glad to help chubbz
Old Jan 15, 2010 | 02:39 PM
  #27
Z'06's Avatar
I was planning a cam around a stock verter for a while and was either going with the 212/218 low lift or the slightly larger 216/220 (100RPM advertised difference in the low end).
But then after enough research, I changed my mind and decided I will first drop in a Circle D 3K-3200K modified TB stall and go with everyone's favorite recommendation for a heavy 5.3L (Tahoe) - the TR220-112.
Dan Neumann
11
Aug 7, 2022 09:06 AM
ARC
57
Feb 21, 2022 10:54 AM
2500ZL1
Jan 25, 2016 06:30 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
