View Poll Results: Vote HERE!!!!
Quik
13
21.31%
GMracer
25
40.98%
trever1t
23
37.70%
Voters: 61. You may not vote on this poll
which cam to get?
Old May 11, 2004 | 08:19 PM
one03sierra's Avatar
Formerly one92rs
Talking
if you are getting a cam that the power band is up high and you want it to come down in rpm then get the advance ground into the cam.
simpler---the cam is rated at2800 to 6500----get 2* ground into it and it will be like -----2300 to 6200. just an example.
Old May 11, 2004 | 08:55 PM
dubrado's Avatar
i understand that, but i dunno what you mean by 'get 2* ground into it'
sorry for the tedious questions, still a newb when it comes to anything other than bolt ons and i dont want to do this twice
Old May 12, 2004 | 08:30 AM
BigKID's Avatar
Say your LSA (lobe seperation angle) is 114... your ICL (intake center line) is 110, you have four degrees of advance ground into your cam, i.e. the intake lobes are advanced four degrees from the the installed centerline. You can also advance a cam by using an adjustable timeing chain.
Here is a good cam write-up onthe other board: http://www.ls2.com/forums/showthread...threadid=19218
SportSide... I am hoping it will ship out today and I can install it this weekend. You can be sure I will post results when I am done.
Old May 12, 2004 | 10:45 AM
dubrado's Avatar
so it installs the same, I just need to find the right cam w/about 2-4* of advance ground
Old May 12, 2004 | 03:24 PM
marc_w's Avatar
LSA's...
TR220 112 is supposed to idle like a TR224 114.
TR220 114 - noticeable lope - easily tuned out with higher idle rpm's and what-not.
TR224 112 - Enough lope to give a deaf man wood.
As I understand it, these pre-made TR cams have 4* advance ground in. You'll want that, especially in a truck application. It moves the power lower in the rpm's. (It's stillg going to be WAY up there over stock)
Old Oct 26, 2006 | 07:37 AM
AeroKing's Avatar
c'mon george
Originally Posted by Flyer
*THIS* is the thread you are looking for. Sorry for the inconvenience.
***This was added by Flyer***
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
