cam finally going in, couple of ?,s
Old Jul 23, 2007 | 09:16 AM
00stepsyde's Avatar
Default cam finally going in, couple of ?,s
I finally started my cam swap last night, TR 220 112, going in 5.3. First is I have read a couple of guys getting the cam out without pulling the radiator out, can it be done, or should I go ahead an pull it out? Second, how does the clutch fan come off, do I pull the 4 bolts on the back of the fan, or hold the pulley and loosen the big nut/bolt behind the fan? Thanks guys and Im sure I will have more questions.
Old Jul 23, 2007 | 09:44 AM
Tootall's Avatar
https://www.performancetrucks.net/fo...&highlight=fan
Old Jul 23, 2007 | 03:21 PM
mabutler's Avatar
The nut, not the bolts. I used a chain wrench wrapped around the pulley to hold it still while I had a cresent wrench on the nut and hit it with a dead blow hammer. It came off easy.
Old Jul 23, 2007 | 06:38 PM
wkdivr's Avatar
The rad will have to come out, but the a/c condenser doesn't. I just finished the GT2-3 in mine.
2500ZL1
Jan 25, 2016 06:30 AM
thunder550
Oct 8, 2015 04:53 PM
Noah Burns
Sep 7, 2015 05:50 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
