Cam or Fans
Old 07-07-2010, 11:25 AM
PT's Slowest Truck
budhayes3's Avatar
I say cam as long as you can get it retuned shortly after, the right cam with the proper tuning will totally change your truck. Gains with efans are minimal...I consider efans an "after the good stuff" mod, at least that's the way I did it.
Old 07-07-2010, 11:37 AM
Wearin' da big hat
00ChevyScott's Avatar
Why not do both? If you're sweating 80-100 bucks on efans, you've got the wrong hobby
Old 07-07-2010, 11:38 AM
white1's Avatar
None of my cams ever drove like ****. I loved every one Ive had. Some more than others.
If youre willing to spend the money ($400ish for cam, $150ish for springs) Id go cam. Youre really not going to see much difference with the fans.
If you want it to idle good etc, youre gonna need it re-tuned, but youd need that for the PCM to control the fans too. I hated manual fans. If you forget about them, or let someone else borrow your truck that forgets, its too easy to let it get hot.
As far as cams go, with most performance cams, youre gonna sacrifice a little low end power for mid to upper RPM gains, some more than others. Im planning to run a 220/220 in my 4.8, but havent decided for sure. Its slightly on the bigger side of what most people run in the 4.8, but oh well, too many people here talk out of their *** about things they dont know about. But the reverse is true also, there are many people that know a bunch too.
For a DD 5 speed with a 4.8, id recommend a 212/216, or a 216/220 personally, but even better would be get a custom cam ground. They cost the same and instead of making an educated guess off of someone you dont know's opinion, you can let someone who specs cams for a living spec something that will make you happy .02
Old 07-07-2010, 11:42 AM
Wearin' da big hat
I was referring to when he is driving it untuned.
Old 07-07-2010, 11:46 AM
jadaven's Avatar
Not actually a cheap hobby I know.
Old 07-07-2010, 12:00 PM
11 Second Truck Club
MPFD's Avatar
Yeah, my X wife bitched about everything I ever bought for my truck. Then I divorced her and I've been happier and faster ever since!!!
Old 07-07-2010, 12:03 PM
TXsilverado's Avatar
Originally Posted by marovetsm
Yeah it will run like complete **** if you get a cam worth swapping, mine would die at every stop sign/light when I stepped the clutch in. Got old REAL fast.
theres a simple fix to that. find a good tuner.
Old 07-07-2010, 12:06 PM
this was worth a 2nd read for the noobies to the site.
Old 07-07-2010, 12:11 PM
dhpro's Avatar
Cam...even tuned properly e-fans arent worth the hassle. So they free up 15+hp, its irrelevant @ WOT cause the clutch fan disengages. U wont feel the diff with fans that u will with a cam. Fans are a PITA - I'd never do them again unless they came stock...voltage drop, lights dim, relays blow (then truck overheats!). Of course if u do them, check out the various harnesses. So far I have yet to find one with big enuf guage to handle the voltage draw without the above probs...
Old 07-07-2010, 12:21 PM
jadaven's Avatar
Lol, I'm working on the wife delete mod now.
Quick Reply: Cam or Fans
