cam comes today!
Old Apr 25, 2006 | 12:25 PM
Yelo's Avatar
Originally Posted by Quik
NOPE!!!!!!!!!!!! more gear should be used, he has a LQ4 and 9.5CR with the MS3. he is going to need all the gear he can get. his power under the curve wont be as good as others. if he bumped up the CR some then it would help with under the curve power. also the 80 is going ot eat up alot of low end which now he is short on some. 410s in the combo is what he should go with or very least 373. its a high reving setup so hes going to need the gear to help him get up there and stay there. if you recall trucks arent the most aerodynmaic friendy rides.
also XtremeS10 if you run 355 up at FLD you wont see nothing but my tail lights.
I'm not sure I agree here.....given that he weighs the same as a Corvette which run 3.23's AND the fact that he'll stall to 4000rpms I think even with the Magic Stick 3 (which I HAVE warned him about) he'll accelerate just fine. I'm betting his number one problem will be traction actually
Old Apr 25, 2006 | 12:27 PM
kbracing96's Avatar
Old Apr 25, 2006 | 04:29 PM
Quik's Avatar
5 year bitches!
i speak from experience with a buddys setup with 342s and they werent enough. granted 355 is a tab higher but still isnt enough
Old Apr 25, 2006 | 05:10 PM
Xtremes10's Avatar
here ya go, worrying me again about cam choice again, lol, i know its going to have a lot left on the table, but hey, gives me a lot to work for right?!
Old Apr 25, 2006 | 05:11 PM
kbracing96's Avatar
Was it in a 3300# car with a 4k stall? I think with 4.10, he would have a hell of a time hooking with anything other then slicks. 3.55 with the 4k stall, should give him a nice pull though first. But that just my opinion, as is yours
Old Apr 25, 2006 | 05:26 PM
Yelo's Avatar
I was givin' ya the benefit of the doubt bro.....it's a BIG cam but I'm betting with a 4K stall and a light-*** truck you'll be having more traction issues than acceleration issues (although you'll probably spin so hard you WON'T accelerate )
Old Apr 25, 2006 | 05:31 PM
Yelo's Avatar
I have issues hooking a 5600lb truck with 4.10's and 32" tall tires, I'll bet with the mods he's going with he'll only make a little bit less torque than I am I am.....4.10's would be serious overkill on something that big if you EVER want to drive it on the street. I've got enough experience with 3500lb race cars to be fairly confident that he'll be fine with 3.55's, especially given the 4K converter !!!
Old Apr 25, 2006 | 06:03 PM
Xtremes10's Avatar
nothing better than the smell of cooked tire!
Old Apr 25, 2006 | 10:01 PM
i agree, the 410 would be way too much gear for his set up, hes already gonna break loose bad, why would you want to just make it worse? you see extreme vettes and stuff and the biggest gear you see on them, other than strict 8th mile racers is a 3.73 usually and with the weight of his truck he should be just fine, if hes stalling to 4k what gear does it really matter at that point? hes already breakin his power band and his motor will be doing most of the work, not the gears, maybe if he was trying to work with a 3k stall the 410+ would be needed...
Old Apr 26, 2006 | 02:54 PM
Quik's Avatar
5 year bitches!
.sorry 410 isnt that large of a gear really. i run that in my stang and have no issues, we built cars with 410s and dont have issues. if you cant hook you set it up wrong easy as that.
yes the setup was in a 3400lb ride. his truck with that setup will be around 3650 with driver. that cam revs to 7k. hell need a gear to help him get there fast and then stay in the upper range with shifting. he also has the 80 for a tranny which also eats up some lowend.
he can run what he wants but deff saying setup up in gear. go do some searching and see most ppl running the MS3 or equilant are running 373 at minimum.
next youll say 410s and my T2 is a bad setup,
or another setup we did with 456s in a 3500 with the Trex.
with large cams that are high rpm range cams you want steep gears
DrX
Aug 19, 2015 04:45 PM
USMCvet0311
Aug 13, 2015 09:59 PM
black03rcsb
13
Aug 13, 2015 04:05 PM
GRRR65GTO
Jul 10, 2015 08:27 PM
