Cam and Check Engine Light ???
Old Sep 7, 2004 | 11:28 PM
OCSSleeper's Avatar
Default Cam and Check Engine Light ???
If I put a cam from a 1998-2000 Ls1 car cam in my 5.3 truck, will it throw on the check engine light?
Old Sep 7, 2004 | 11:31 PM
Flyer's Avatar
SHouldn't ... that isn't by any menas a big cam.
Old Sep 8, 2004 | 05:56 AM
BigTex's Avatar
I think the current 6L cam is a bit larger than that one. Neither should throw a code if its installed correctly.
Old Sep 8, 2004 | 12:39 PM
OCSSleeper's Avatar
What do you mean buy installed correctly???
Old Sep 8, 2004 | 12:49 PM
vanillagorilla's Avatar
I think he means if you install it straight up. With no advance or retard, like the factory did. Then you shouldn't have a problem.
Old Sep 8, 2004 | 12:59 PM
BigKID's Avatar
I didnt throw one with my 2K vette cam.
Old Sep 8, 2004 | 10:39 PM
eallanboggs's Avatar
If you have a low LSA you increase you chances of the P0300 DTC. The factory LSAs are around 115. Try installing a 112 or less and see if the SES MIL goes set.
Old Sep 8, 2004 | 11:07 PM
FILE's Avatar
My comp cam on a 114 lsa did set off the PO300 code.
Old Sep 12, 2004 | 01:19 PM
OUT2WIN's Avatar
I am in the process of getting a cam with 114lsa, what is the PO300 code and will the hpp3 get rid of it? I know, I know HPTUNERS or NELSON TUNE is on the way.
Old Sep 12, 2004 | 01:24 PM
Black02Z71's Avatar
PO 300 is random cylinder misfire
HPtuners will fix, this HPP3 will not.
ARC
57
Feb 21, 2022 10:54 AM
tweeder
Sep 18, 2015 11:02 PM
Ketis
Jul 23, 2015 12:37 PM
bsgiffor
Jul 19, 2015 11:14 AM
hackrst
Jul 11, 2015 11:17 AM
