cam
Old Oct 18, 2005 | 09:07 AM
Default cam
which would be a better cam and would like video or even audio of these 2 cams if possible the thunder racing t rex cam or the trak cam. please help
Old Oct 18, 2005 | 09:55 AM
NightmareTBSS's Avatar
i dont have a video but a buddy of mine that attends LSU for engineering works for Thunder and he recomened me the trak! on a 5.3 but yours is a 6.0 im not sure if it would matter much but he said its a very stong cam....ill talk to him and see what kinda numbers both of these cams make...
Old Oct 18, 2005 | 10:04 AM
ok thanks and also see if they will work good with nos and a turbo. gas mileage doesn't matter to me. it is going in a 408 stroker.
Old Oct 18, 2005 | 02:48 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Here you go here is a clip of a car with a 408 in it with a cam thats a bit bigger than a t-rex so the t-rex will be a bit more muffled and also the car has an open y-pipe so it osunds kind of poppy.
http://videos.streetfire.net/Player....2-44BFBA610228
Old Oct 18, 2005 | 03:47 PM
what compression ratio do you have and are planning to have any FI and what compression would you suggest i get to run with the t rex cam and do you think that cam would be a good choice for me.
Old Oct 18, 2005 | 05:41 PM
1slow01Z71's Avatar
Im am basically going to be running a t-rex cam in my truck but just a hair smaller. You can definately get away with in your much lighter truck. I am going to be running 10.7:1 CR if you are going to be running FI then you need to be around 9:1 IMO.
Old Oct 18, 2005 | 07:10 PM
some people are telling me that the 110 lsa wont be any good with the nitrous or even FI
Old Oct 18, 2005 | 08:40 PM
1slow01Z71's Avatar
Yeah a 110lsa isnt as good for FI or nitrous. It makes your n/a performance better but at the expense of the power adder performance. The cam in my sig will work good for FI and nitrous, it could use a bit wider lsa you might look into a TSP MS3 cam they are on a 113lsa and is a high lift and long duration cam. Are you going to put a turbo on it or not. If not then go with a narrower lsa if you are then get something in the 113-115lsa.
Old Oct 18, 2005 | 10:16 PM
if i get good enough power out of this setup then i more than likely wont go FI but might settle with just 5psi because i can get it from a friend dirt cheap. but i would like have awsome power out of all motor by itself na
Old Oct 18, 2005 | 10:18 PM
1slow01Z71's Avatar
Well hell hook me up then Ill buy it from then.
You will get plenty of power out of the 408 if oyu go with a decent size cam and good heads with a decent CR then you can spray it when you need to and a forged 408 can handle a 200shot easily and be pretty reliable.
