calling all edit guys URGENT!
Old Nov 2, 2004 | 09:20 AM
Default calling all edit guys URGENT!
here is the situation:
fathers 03 SS p1sc 10psi, comp 212/218 .529 .532 114lsa, headers, no cats, cutouts, new 8.1 liter injectors
*looking for a sample of the ifr rates & pe tables for similar setup to get me in the ballpark, truck is sitting at the shop now waiting for me to tune it, even if running less boost would be ok.
Old Nov 2, 2004 | 09:43 AM
Flyer's Avatar
Use 5.15 for a good starting point on the injectors. The VE table doesn't need to be messed with if you've just put the new injectors in. If the cam's new, then you need to adjust the bottom end of the VE table a little.
Old Nov 2, 2004 | 09:47 AM
MMMY PROBLEM IS THAT I USED THE PE TABLE TO TUNE IT, I enriched it quitte a bit trying to get the afr correct before realizing we ran out of injector
Old Nov 2, 2004 | 09:53 AM
Black Blown 02's Avatar
Sounds like you either need bigger injectors or a bigger supercharger pulley.
Old Nov 2, 2004 | 10:17 AM
Flyer's Avatar
Can you put a stock tune back in it, or get a stock tune from another truck and do some copy/pasting?
Old Nov 2, 2004 | 10:47 AM
I just was trying to get somewhat close, that would make me start all over again, the pcm is a bitch to take out with the supercharger.
Old Nov 2, 2004 | 10:49 AM
So do you just need the stock PE/RPM numbers?
Old Nov 2, 2004 | 01:44 PM
Flyer's Avatar
The tables will be different for a 5.3 and for both 6.0's.
BKnBLK05
Dec 28, 2015 08:52 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
