CAI install truck runs like crap
Old Oct 20, 2007 | 02:52 PM
9 Second Club
Default CAI install truck runs like crap
I installed a K&N CAI and now my truck flags the MAF and runs like crap. I checked and double checked for air leaks and have none. I put the stock air box assy back on and thr truck runs fine. I tried the K&N system again with the same results. Anyone else had this happen?
Old Oct 20, 2007 | 03:25 PM
TG02Z71's Avatar
Did you disconnect the battery for a while so the computer would re-set and relearn your idle and cruise mode? You should.
Old Oct 20, 2007 | 03:41 PM
BlackLM7's Avatar
Hey Lorenz. I've heard of people having similar issues with their MAF after a CAI install and some were resolved by TG02Z71's suggestion. I'm sure you checked this but were all the wires still hooked to the MAF? Did any of the filter oil get on the MAF? I'm stumped otherwise.
Chris
Old Oct 20, 2007 | 07:54 PM
9 Second Club
I reset the pcm and even tried to fix it in the tune with no luck. With the CAI installed the truck just keeps flagging the MAF. I went back to stock and drove it around all day with no problems.
Old Oct 20, 2007 | 09:29 PM
budhayes3's Avatar
PT's Slowest Truck
Thats wierd, usually when that happens it's because the MAF is coated in oil from the air filter, but since it runs fine when put back to stock, I guess you could rule that out. Is it possible that since the CAI slightly relocates the MAF, the harness/connector is getting pulled and losing connection? Or maybe the filter is damaged or over-oiled and now flowing properly?
stealthperf
34
Feb 14, 2016 11:35 AM
The_W
Oct 28, 2015 09:00 PM
therock
Jul 25, 2015 09:23 AM
black6spdz
Jul 16, 2015 01:32 AM
