buying cam, need advise
Originally Posted by bluecajun5.3
yes it sure will perform well if tuned right!
Your going to need TQ @ lower RPM due to your short stroke/smaller motor. TT3000 isn't a very big converter. A 220 cam will MPH good (HP), but the shift extensions of the TT is pretty weak. 1-2/2-3 shifts will drop back down to 4000 RPM approx. This isn't any good. That big cam isn't make BIG HP at 4000 RPM, nor big TQ because the duration is too large. Pick your cam wisely. 220 isn't the magic number for every combination. Good luck.
well heres whats going on!!!! i just found and buying a LS1 for $1700 and have a 222/224 112 cam with a TT3000!!! now i have to figure out all the other parts i need for the swap. i would like to have car intake with all car accessories but dont know what all i need for this swap?!!
is it a complete LS1, as in including the accessories and intake and if not, to swap to car intake you need a intake manifold, idler relocation bracket, f-body water pump with truck pulley pressed onto it, fuel rails, injectors
congrats on the ls1 find
it has the crank pulley, and waterpump with pulley, intake and fuel rails and injectors as far as i know!! I'll probably use the truck accessories and get the relocation bracket, i think that would be easier
BIGD4504
Jul 28, 2015 11:46 AM
sauldgold
Jul 23, 2015 02:15 PM
