Burn Out
Old Sep 9, 2004 | 10:34 PM
jngannon1's Avatar
Default Burn Out
I have a 2001 Tahoe. With a 5.3L, 3.73 gears, K&N Intake, Stock MAP with screen remove, Magnaflow exaughst and Superchips programmer. I currently have proxy 305/60/18's on it. It has a traction ON and OFF button and will not spin the tires either way. What does it take to do a burn out. Help
Old Sep 9, 2004 | 10:54 PM
trucksleeper's Avatar
First off why do you want to do a burnout in that. And to do one in that turn the traction button off and press the brake gentley then give some gas at the same time keep giving it gas until it starts to spin the wheel but it still may not do it because it is such a big vehicle.
Old Sep 9, 2004 | 11:02 PM
Mangled03gmc's Avatar
Baltimore Whore
more than likely it won't do it because it is so heavy.plus you have 18 inch wheels.my friend has one and so far the only way it's been done is get a few peeps to pick up the back some.try it wit the stockers.the brake system may have something to do wit it
Old Sep 9, 2004 | 11:12 PM
Deckhand's Avatar
press the brake and floor the pedal. ease off the brake pedal if needed.
Old Sep 9, 2004 | 11:21 PM
James B.'s Avatar
I know what you mean. It's the weight. The converter stalls at too low of an RPM to let the engine make enough torque to overcome the traction and the brakes. The full-size SUV's are heavy in the back. Be careful with that 10-bolt, under the weight of an SUV they do not stand up to abuse. Of course you could always get it painted. Green Tahoes can smoke the tires any time you like.
Old Sep 9, 2004 | 11:38 PM
moregrip's Avatar
what a rush!
water.
Old Sep 10, 2004 | 12:33 AM
BurnOut's Avatar
Whoa, ****... I thought you were talking to me there for a second... I was all, "WTF did I do?!?!"
Old Sep 10, 2004 | 12:48 AM
LOL
Old Sep 10, 2004 | 01:52 AM
Tokez420's Avatar
haha my homie has an 04 yukon and has the same problem
Old Sep 10, 2004 | 06:51 PM
that must really suck my 2001 tahoe burns like a ************ and i drive it hard as hell and change the oil like every 20, 000 miles
