built 6.0 help
Old Feb 6, 2009 | 10:22 PM
gmc6.0's Avatar
Default built 6.0 help
hey guys i need recommendation or suggestions...im lookn to spend 10k on a new setup here are my plans
front mount turbo
custom cam,lifters,rockers,springs,rods
balance crank
install diamond pistons
60lb injectors
meth or wet kit undecide
anyone think i can keep all this under 10k
i already have a built 65e and an intank 255 pump tryn to boost 12-15 psi. my goal is to make 750 rwhp on a crew cab 2wd sierra am i shooting to high need help.....
Old Feb 6, 2009 | 10:56 PM
stock48's Avatar
9 Second Truck Club
front mount turbo
balance crank
60lb injectors
You should be close to getting it running for that but most likley will be over when it is all said and done. you are also going to need connecting rods. What do you plan on doing for smog?
Old Feb 8, 2009 | 06:11 PM
gmc6.0's Avatar
any more suggestions
Knightcrawler
Jul 20, 2016 03:29 PM
Pontiac Derek
Sep 19, 2015 01:49 PM
Pontiac Derek
Sep 18, 2015 09:02 AM
Justin87gn
Sep 10, 2015 12:06 PM
chvy=power
Sep 8, 2015 11:06 AM
