building a budget daily driven 6.0 input needed
Old Jan 12, 2006 | 11:47 PM
ls1ow's Avatar
Default building a budget daily driven 6.0 input needed
so im building a 6.0 for my rcsb truck its a stock LQ4 short block, im planning on using my stock 5.3 heads with GM MLS head gaskets and a im considering a TSP 228/228 .588 .588 on a 112, the cam is probley my major concern, so some of yall that have built 6.0s please chime in and give me your knowledge.
thanks,
John M.
oh forgot to mention i have a fresh 4l60e with vette servo, and a Yank SST 3200 and 3.42s
Old Jan 13, 2006 | 07:40 AM
slowprocess's Avatar
thanks,
John M.
Looks like a nice setup to me. You have more cam than I'm running in my 6.0L, more stall, and less gear. If you're going NA, you might want to get the heads milled down some or use a thinner head gasket. My heads were hand ported/polished and milled, and I'm using a thinner gasket. Are you planning on using the 918 springs? I'm happy with them and they are pretty affordable. If the tranny only has a vette servo, be prepared to yank that thing back out fairly soon. My was fully built and it lasted about a year. That's a great stall to go with on that cam choice. Wish I would have gone up to a 3200-3500 instead of the 3000.
Good luck with it.
Edit....just read you didn't get the heads with the 6.0L. I would look into getting my hands on a set for an affordable price and get the work done to them.
Old Jan 13, 2006 | 01:27 PM
onebadrubi's Avatar
Slow process....why did your built 4l60e only last a year???
Why would it be better for him to 6.0l heads instead of the 5.3l. I thought the 5.3l flowed better?
Y do you regret only gettin a 3000stall. Im lookin into gettin a 2800-3000 for my dd 5.3l with stock cam(for now) and 4.10 gears. should I go bigger hten 3000?
Not trying to hijack the thread
Old Jan 13, 2006 | 01:32 PM
ls1ow's Avatar
yea thats kinda fisshy that your built tranny only lasted a year??? not that ive never seen it done had plenty of buddies with there f-bodys 4l60s not last a year either, but everytime, we would all come to find out it wasnt as built as they thought, and im gona run 918s used them on my 99 TA with a bigger cam and ran for 15k miles with no problems, and comp only reconmends them for 10k miles
Old Jan 13, 2006 | 03:08 PM
white1's Avatar
Im not slowprocess, but I may can help answer a few of these questions
The 317 casting 6l heads have larger valves, and flow better than the 5.3 heads. Even if you put bigger valves in the 5.3 heads, you run into problems with shrouding the valves.
A 3000 stall would be great for a stock cammed truck. He was recomending a larger stall because of the cam size (I think)
Im sure if I misrepresented the southern way of thinking hell correct me. Hope that helps a little
Old Jan 13, 2006 | 03:12 PM
white1's Avatar
The trucks are a lot heavier than a f-body. I know a few f-body guys that have had tranny problems, but almost everyone I know that has done a6l swap in a truck has problems with the 4l60. When you do a complete build, you dont always replace all the hard parts, from what I understand th esun gear shell has a tendency to crack as well as other things. Depending on how "built" it was would depend on the strength. I have a "built" tranny, but I dont have the "beast" sun shell, or the 5 gear planateries.
Man that sucks about the longevity of the 918's I wasnt planning on replacing them every year. What a bitch.
Old Jan 13, 2006 | 04:35 PM
ls1ow's Avatar
well the 918 strength rating is at .600 lift which is the max that they recomend, for 10k miles, so less lift on the cam more longevity they will have
5.3lSilverado
25
Aug 29, 2016 12:48 AM
USMCvet0311
Aug 14, 2015 10:28 PM
lxcoupe
Jul 14, 2015 10:14 PM
4B11T
Jul 13, 2015 03:48 PM
kdw8888
Jul 9, 2015 10:52 PM
