Building the 5.3: Head gaskets? Head studs?
Old Jan 28, 2006 | 08:30 AM
JimS's Avatar
Default Building the 5.3: Head gaskets? Head studs?
The 225 Dart heads are on the way, 62cc chambers. The cam will be ordered Monday (224/230 581/588 114) and the meth kit won't be far behind. I have a 3.0 and a 2.8 Radix pulley coming from Nelson and I suppose I"ll be looking at about 10 psi boost.
I will be getting the ARP rod bolts as I plan to spin to about 6800/7000.
I don't want to throw money away if not needed so do you folks think I need the Cometic gaskets and ARP head studs?
Thanks, Jim
Old Jan 28, 2006 | 08:36 AM
TurboGibbs's Avatar
I'm going to use ARP head bolts. They run ~$139. The studs are $100 more. I picked up the factory head gaskets from the dealer for $31 each. They are multi layered steel like the Cometics. I'm unsure of how much, if any, the cometics are better than stock. Same basic design. At your boost level I doubt you need to spend the extra money on the cometics. I was running 12lbs boost and had a spout of detonation and my stock head gaskets never went, I can't same the same for 3 pistons
Sounds like you are going to have a bad ride!
Old Jan 28, 2006 | 08:51 AM
JimS's Avatar
It ought'a run pretty strong.... for Gramps and the grandboys.
Old Jan 28, 2006 | 08:55 AM
TurboGibbs's Avatar
I really like your reasoning to build the truck is to save money....Gonna give the grandkids such a ride they will forget about Disney World
Old Jan 28, 2006 | 10:13 AM
Buy the best head gaskets you can find,not having to replace them will save you money in the long run.I run steel o-rings with my setup,overkill maybe but I've never had a problem.
Old Jan 28, 2006 | 11:59 AM
JimS's Avatar
Got it.... I think. What are steel o rings? Where can I get Cometic gaskets. Not at Summit or Jegs. Strange.
Do you think the ARP head bolts are ok or do I want ARP head studs?
Thanks, Jim
thunder550
Oct 8, 2015 04:53 PM
JordanH
Aug 8, 2015 07:59 PM
bbowerman
Jul 26, 2015 10:57 PM
jmarkway
Jul 18, 2015 09:23 PM
