Build a 5.7 or leave it a 4.8
Old Feb 13, 2011 | 10:39 AM
lsvega-s's Avatar
Default Build a 5.7 or leave it a 4.8
I have a 4.8 that is apart now. I was going to swap in a 5.3 crank and rods but found out that the 4.8 has press fit pins and the 5.3 is floating. Now I don't know what to do. I have two blocks and can get a set of 5.7 ls1 pistons with 22,000 miles on them. I guess I am wondering if I should punch out one of these and build me a 5.7 or just bolt the 4.8 back together and run it.
The goal is around 350rwhp or as close as I can get anyways. It is going to get a cam, ls1 intake, and 1 3/4" or 1 7/8" headers depending on the cubic inches. This is all going in my 1976 vega wagon with either a 4l60e or a 200-4r. It is not a dd but will be driven a lot when the weather is nice. Thank you all for the input.
Old Feb 13, 2011 | 10:49 AM
charcoal03silvy's Avatar
Gotta look at price : power ratio. Most people will say punch it to LS1 specs
Old Feb 13, 2011 | 11:04 AM
zippy's Avatar
The early 4.8L and 5.3L did have press fit pistons. It was somewhere around 2005 that the 4.8L and 5.3L went to a full floating piston. It looks like what you have is just a problem with the years of the parts not interchanging. If you were looking to rebuild it though, the 5.7L build will give you quite a bit more power over what you have right now. The machine work and balancing will be your only main expense.
Old Feb 13, 2011 | 11:07 AM
06Sierra2's Avatar
no replacement for displacement!
Old Feb 13, 2011 | 11:21 AM
lsvega-s's Avatar
Yeah that is my thought. I have the crank, rods, and the engine is already torn down. The pistons are cheap and I think I would really like the extra displacement. I will be replacing the bearings and all anyways since it is this far apart.
If I do this and still run the 862 heads, with a port and polish job, what will the compression be?
Old Feb 13, 2011 | 03:38 PM
lo&sloSierra's Avatar
i just finished building my iron 5.7....i used the 862's but did a 3 angle valve job and put in ls1 intake valves...compression was 11.06:1
Old Feb 13, 2011 | 04:10 PM
lsvega-s's Avatar
Cool thanks a lot.
Old Feb 13, 2011 | 07:38 PM
no problem, good luck with the build
Zizzle
Oct 19, 2017 08:44 PM
USMCvet0311
Aug 14, 2015 10:28 PM
JordanH
Aug 8, 2015 07:59 PM
4B11T
Jul 13, 2015 03:48 PM
Cowboy17
Jul 9, 2015 08:22 PM
