Budget 6.0 Build
Old Oct 25, 2007 | 12:26 PM
maikell77's Avatar
Default Budget 6.0 Build
I'm thinking about getting an LQ4 short block. Then putting on a set of ported 5.3l heads that I have sitting around. I'll be using a stock short block, just a re-ring and new berring rebuild. Then I was going to use a set of used LQ9 injectors, manley pushrods, slp double roller timing chain, and oil pump. Then for cam I was thinking of going with the LS1 Hot cam.
I'm looking to get around 450hp out of it but have a reliable engine. I'm also looking to do it as cheaply as possible. Using the parts I've listed i'm guessing I can do it for $2k.
Just wanted to see what you guys think of this kind of build up, and what tips you might give.
Thanks
Old Oct 25, 2007 | 12:28 PM
maikell77's Avatar
Oh by the way its going in an 02 ECSB wiht 104K on the stock motor. It's 2wd, 3.73 posi rearend and I've already got all the standard bolt ons. I also have Hp Tuners and have been doing my own tuning.
Old Oct 25, 2007 | 12:48 PM
green6.0's Avatar
pretty much the same setup im running but im on stock ls1 heads with a comp 232 cam in a scsb. never had it dynoed or ran in the quarter but the 1/8 it runs 8.30s with no stall and street tires. I paid 1,100 for a fresh built short block from hke and paid 1700 for install and gaskets and everything.
Dan Neumann
11
Aug 7, 2022 09:06 AM
BoostedBowTie
Jan 3, 2020 06:46 PM
spiritfish
Aug 23, 2015 09:58 PM
USMCvet0311
Aug 14, 2015 10:28 PM
steves86ta
Jul 28, 2015 10:21 AM
