Broken off exhaust bolts
Old Jul 6, 2010 | 01:29 PM
Atomic's Avatar
I have a gauge for that
Default Broken off exhaust bolts
I didnt even realize any were broken off inside the head before this weekend since they were broken past the surface. I tried using a bolt extractor but broke it off in the hole Any suggestions?
Old Jul 6, 2010 | 01:33 PM
Mangled03gmc's Avatar
Baltimore Whore
Hell your gravy, cuz the heads are off.. Take a nut, set it over top the broken stud, weld down inside the nut hole, so it welds the nut to the broken bolt..
Old Jul 6, 2010 | 01:41 PM
TX Tahoe Z71's Avatar
Could you drill it out with a hardened bit? I would soak it in PB Blaster or Kroil for a bit if you are going to try and back it out though, that should loosen it up.
Atomic's Avatar
Wont that damage the heads? Turn the nut sideways, or flush with the head?
Tried drilling it out with cobalt bits, not much luck.
Old Jul 6, 2010 | 01:54 PM
Baltimore Whore
Use a 3/8th nut, so that hole in it is about the same size as the bolt hole. Lay it open end up, so that you can see the stud ofthe broken bolt. Weld strait down so that it welds the broken bolt to the nut. USE A NON GALVINIZED bolt. It might melt the area around the hole some, but nothing that should cause issue, or that can't be cleaned up. I have done it a few times, with out issue..
Old Jul 6, 2010 | 02:23 PM
hirdlej's Avatar
I'd try notching it and use a big wide screwdriver in the notch. Then just unscrew
Old Jul 6, 2010 | 02:33 PM
MPFD's Avatar
11 Second Truck Club
LOL
Old Jul 6, 2010 | 02:35 PM
TIM Z's Avatar
11 sec. Truck Mod
Matco sells the best bolt extractors ive ever used.
My Tech friends and the dealer use them alot.
Old Jul 6, 2010 | 02:40 PM
DV2000NJ's Avatar
13 Second Truck Club
So I'm not the only one who breaks off extractors making the bolt 10 times harder to remove.
Old Jul 6, 2010 | 02:53 PM
ssinister04's Avatar
hahahaha i did this same thing in my swap! my guy did the nut trick and it came right out!
