Broken Manifold Bolts??
Old Jan 27, 2013 | 06:29 PM
kevins01silverado's Avatar
Registered User
Default Broken Manifold Bolts??
So i have recently ordered a set of lt headers for my 2001 silverado 4.8l and i have noticed that on the passenger side the rear bolt head is snapped off and on the driver side the front bolt head is snapped off. Once i take the manifolds off there will be some of the bolt sticking out because they broke flush with my stock manifolds. so my question is how am i going to get out these two bolts? Maybe vice grips? thanks, kevin
Old Jan 27, 2013 | 06:37 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
If it's sticking out of the head, you're in luck. On those, Knipex Alligator pliers are the best way to go in my opinion. Way more grabbing power than Vise-Grips. They are a good addition to any toolbox.
Old Jan 27, 2013 | 06:40 PM
Registered User
that makes me feel a lot better hearing that!! are those the same as a regular set of pliers for the most part?
Old Jan 27, 2013 | 06:48 PM
This style of pliers have a TON of leverage and holding power, and the teeth are aggressive, lots of traction on your broken bolt.
http://www.aikencolon.com/assets/ima...plication2.jpg
Old Jan 27, 2013 | 07:01 PM
Registered User
Thanks i appreciate it! also another thing i was wondering was if for some odd reason this didnt work should i resort to an extractor or not?
Old Jan 27, 2013 | 07:05 PM
If that doesn't work, then get a nut, and weld it to the bolt through the center of the nut. Then you can use a wrench to remove it. And the heat from the welding helps a bunch.
If you try to drill it, you stand a pretty good chance of drilling off center, or even breaking off a drill bit or extractor in the bolt. Then you're screwed.
Old Jan 27, 2013 | 07:07 PM
foggy's Avatar
If you have a welder, weld a nut to it and use a socket or wrench to pull out.
Old Jan 27, 2013 | 07:11 PM
Registered User
thats what i was considering, but what are the chances though of messing up the weld and ruining my heads though? i believe they are aluminum :/
Old Jan 27, 2013 | 07:16 PM
I'm not a very skilled welder, and I haven't had that happen to me yet.
Old Jan 27, 2013 | 07:25 PM
foggy's Avatar
Get a nut that is bigger than the bolt and put a couple of tack welds on top.
