broke off header bolt
Old Mar 16, 2006 | 06:39 PM
greentahoe's Avatar
Originally Posted by 5.3 racer
weld a washer to what's left of the bolt and then weld a nut to the washer. while it's hot melt some wax on it. i work in a machine and trust me it works great on broken studs.
This is the way to go if you can get in there. I just got my 04 LQ4 and that same bolt was broken, Im wondering if it happens on the production line sometimes. Too bad you didnt notice it while it was under warranty
Old Mar 16, 2006 | 10:07 PM
treyZ28's Avatar
If that doesn't work, just pop the head off. its 20 minutes from where you are at now. Take it to a machine shop and give them $15.
ohh yeah, PB blast the **** out of it before trying anything. Maybe even heat up the bolt too (careful, PB will catch fire. heat it up first, then PB blast!)
Old Mar 19, 2006 | 08:46 AM
ktmrider's Avatar
Unfortunately this is a very common problem on these motors ( saw the same thing x2 ) and is in the worst place to fix on the vehicle.
Best bet is to try what 5.3 suggested else pull the head off.
Old Mar 19, 2006 | 11:35 AM
greentahoe's Avatar
I have 3 that broke on me. What do you guys connect the grounding clamp to?? Will it toast the sensors with them in the block if I connect it to the block?
Old Mar 19, 2006 | 12:41 PM
Pewter Pro-Tec's Avatar
I have used this trick a couple times and I like it cuz it works. What is the purpose of the wax? I may need to keep some handy.
Old Mar 19, 2006 | 06:25 PM
5.3 racer's Avatar
thread lubricant.
Old Mar 24, 2006 | 05:31 PM
ByuTrukr's Avatar
formerly ByuTrukFreak
Just put Gibson Shorties on my 99 Silverado w/5.3. Found the same problem,last bolt on drivers side broken flush with the head.The exhaust manifold didn,t leak so I put the header on like it was,so far no leaks.
Old Mar 24, 2006 | 08:32 PM
TurboGibbs's Avatar
I bet it was the same moron on the assembly line that was doing it all .
Old Mar 26, 2006 | 04:58 PM
superchevy00's Avatar
ya, I just went ahead and bolted mine back up. The bolt actually was broken a little in the head and I was able to cut a bolt and get like two threads to grab. (I don't really think it made a difference though because I didn't want to torque it too much and strip the threads). I do hear somethig making a pht pht pht sound on the drivers side and will have to tear back into it when I get a chance.
Thanks for the suggestions though....
zblee
63
Jun 10, 2023 01:25 PM
chopperloco
Jul 10, 2016 10:45 PM
ss454327
Oct 17, 2015 03:43 PM
mr03silverado
Jul 26, 2015 01:05 PM
4B11T
Jul 13, 2015 03:48 PM
