Brake upgrade for trucks.
Old Nov 15, 2003 | 11:48 AM
Hit Man X's Avatar
Originally Posted by MonteCarlo31
Hey, I am the loser that doesn't have a truck but knows all about them or at least a lot so here it goes. Back in the day (2001) the GMC Sierra C3 came with bigger rotor and calipers. I bet money if you bought those parts from your GMC dealer they'd bolt right up and there would be no need to change front to back brake pressure. Also, these are 6 bolt lugs not 8. Several places stated that they were 3/4 ton brakes w/ 6 lugs instead of 8 hence the fitment. I hope this helps some.
Lenny
C3's came with 17" wheels too. Would you need the 17" or larger to clear them?
Also are the C3's rotors larger in diameter and thickness?
Elaborate more please.
Old Nov 15, 2003 | 01:35 PM
mudz5.3's Avatar
Hey N8, I had to take the plunge, bent over without vaseline!!!. 380 for my cost pads and rotors for the rear. It helps not hearing the grinding noise any more but I am gonna be walking funny for a little while Later
Old Nov 15, 2003 | 01:39 PM
MonteCarlo31's Avatar
Hit man, I am not sure to be honist with you. I wouldn't beleve so but I am not sure. If they are 3/4 ton brakes which come with 16"s wouldn't the 1/2 16"s fit?
Not Sure though,
Lenny
Old Nov 15, 2003 | 02:27 PM
Hit Man X's Avatar
Not Sure though,
Lenny
Hrm, well this shall take more investigation prolly. I asked about those Tahoe/Avalanche/Burban rear calipers a while ago...GM should include those on the heavy *** trucks like my Z71 too.
I think those C3 rotors you are talkin about are a larger diameter like the 2500 non HD and 2500HD ones...
Old Nov 15, 2003 | 04:11 PM
Banned
is it just the rear calipers that are different on the SUVs or front/rear?????
Old Nov 15, 2003 | 04:15 PM
Hit Man X's Avatar
I think just the rears are different...
Old Nov 15, 2003 | 04:44 PM
Banned
isn't something like 70% of braking done by the front brakes??
Old Nov 15, 2003 | 08:49 PM
StupidFast's Avatar
The front calipers are the same on all half-ton models, both trucks and SUVs. I was thinking maybe you could buy some aftermarket rotors and pads. They would be cheaper and better than Chevys. Then go buy the calipers and capiler brackets, maybe at a junkyard. Just be sure you buy Burban aftermarket rotors.
I am not sure of the C3 brakes, if I remember I wil chek Monday.
Old Nov 15, 2003 | 11:58 PM
Well like I said before Slowverado I believe that with the C3 you get at least bigger rotors and maybe even two piston calipers. Let me do some checking.
Oobray
Jun 13, 2022 03:38 AM
Steve-O-08
Apr 19, 2018 09:32 AM
SLOPONY
20
Oct 18, 2016 06:05 AM
YenkoST
Dec 2, 2015 11:36 AM
4B11T
Jul 13, 2015 03:48 PM
