brake rotors
Old Aug 2, 2003 | 11:38 PM
ThunderZ28's Avatar
12 Second Club
Default brake rotors
anybody hear of the emergency brake wearing down the inside brake pad on the passenger rear prematurely? went to a brake shop today and they gave me this line. the inner pad is totally gone, and has ruined the rotor. was thinking about resurfacing, but might look into just getting new rotors for the rear.
Old Aug 2, 2003 | 11:41 PM
goshawk23's Avatar
Truck addict
Default Re: brake rotors
ok, well, i might be wrong on this, but i was thinking the emergency brake was on the inside of the rear brake drum/roter. isn't the rear both..?? hence the big drum and not the same look as the front. sorry fellas, i am probably wrong so don't shoot me too bad here.
Old Aug 2, 2003 | 11:47 PM
ThunderZ28's Avatar
12 Second Club
no your right the guy showed me where the e-brake is and its on the inside of the brake rotor. something to have to do with the spring on the brake cable just trying to figure out if he is giving me a line of bs. 110.00 dollars for a break job. kinda hesitant on throwing that kind of money down, on something i have never heard of before. he said it happens alot to the Z71's alot but he hadn't seen to many 1/2 tons with this problem
Old Aug 2, 2003 | 11:52 PM
goshawk23's Avatar
Truck addict
my two cents. if your brakes work fine and the problem is with the ebrake, then i would rather save the money and carry a block of wood around so i could spend the 110 else where. truthfully, i never use my ebrak, now if the outside of the roter is damaged, well, you kinda need it, i'd look at junk yards to find some before i purchased new ones. a little time on your part could save a lot of money.
Old Aug 2, 2003 | 11:54 PM
ThunderZ28's Avatar
12 Second Club
thanks, will think about that option hard
Old Aug 2, 2003 | 11:55 PM
Quikenuf's Avatar
Hes not shiting you.. same thing happened to a friend of mine.. the damn ebrake just drags all the time on his truck. so he did the same thing let it wear out and totes a nice pretty 110 dollar saving block of wood.
Old Aug 2, 2003 | 11:57 PM
ThunderZ28's Avatar
12 Second Club
so what did he do to correct it? if i leave it alone. it'll do the same to the next set
Old Aug 3, 2003 | 12:04 AM
goshawk23's Avatar
Truck addict
well, i probably wouldn't get pads for the inside of the brake drum. just the outside rotors. now if the rotors need turning, take'em to advance or autozone, etc, they can turn brake rotors. tell them to leave the inside alone. then go about your business. like i said, my tranny hold well enough that i don't need a ebrake.
Old Aug 3, 2003 | 12:11 AM
ThunderZ28's Avatar
12 Second Club
thanks.
Old Aug 3, 2003 | 12:17 AM
goshawk23's Avatar
Truck addict
01_thunder, sorry i really couldnt' be of more help, i would like to see you save some money and say f-the ebrake. but if you are anything like me, every aspect of your truck has to be top notch. i think my wife gets pissed when i want to change the oil sometimes. (almost bi-weekly) lol
