Bore a 4.8L?
Old Dec 17, 2006 | 10:18 PM
  #21
treyZ28's Avatar
Originally Posted by StrikeZero
Hmmm . . . I was thinking of builing up a high revving 4.8 for my AutoX car . . .
4.8 = $800
LS anything = $1800+ (At least in my neck of the woods)
A crazy wild cam in a 4.8 @ 7200 rpm w/ T56 and 4.44 be a dream 2800 lbs car
you'd still be better off with the 5.3. If you're really hard pressed to destroke, use a 4" bore block (Ls2, LQx) and a 5.3 crank.
Old Dec 18, 2006 | 04:16 AM
  #22
Don't forget the z06 cam. I've heard those make great power w/ the 5.3L heads.
Old Dec 18, 2006 | 06:24 AM
  #23
TURBHOE's Avatar
the 5.3 crank is the same as all the rest. the 4.8 and the ls7 are they only ones with drifferent cranks.
useing all stock 5.3 and 4.8 pistons is just a high compression 5.3.
Old Dec 18, 2006 | 08:56 AM
  #24
vanillagorilla's Avatar
Ummm....that's a 6.0L.
Old Dec 18, 2006 | 09:35 AM
  #25
treyZ28's Avatar
whoops, 4.8 stroke.
Old Jan 14, 2007 | 04:39 PM
  #26
Suddog's Avatar
So if the 4.8, 5.3, and 6.0 all have the same bore just different stroke, does that mean if you wanted to make your 4.8 into a 6.0 just add crank, rod and pistons to the 4.8 block and you have the 6.0? I am sure the heads would have to be different right?
Old Jan 14, 2007 | 05:34 PM
  #27
brodystruck's Avatar
The 6.0 has a bigger bore then the 4.8 and 5.3
Old Jan 14, 2007 | 05:43 PM
  #28
Suddog's Avatar
Thanks brodystruck, I kinda figured it would have to be more to it than switching crank, cause then my 4.8 would be worth a ton more.
Old Jan 15, 2007 | 09:44 PM
  #29
screamingjimmy's Avatar
Now if I built up one of them High compression 5.3's, what kind of compression would I be looking at?
Basically I would have to look for a 5.3 crank and rods!
lukn4trbl355
Oct 21, 2015 11:19 PM
Wolftrk99
Oct 2, 2015 08:17 AM
lycominghunter
26
Sep 25, 2015 07:50 AM
Big_pimie
Sep 22, 2015 09:07 PM
