Bore a 4.8L?
#21
Originally Posted by StrikeZero
Hmmm . . . I was thinking of builing up a high revving 4.8 for my AutoX car . . .
4.8 = $800
LS anything = $1800+ (At least in my neck of the woods)
A crazy wild cam in a 4.8 @ 7200 rpm w/ T56 and 4.44 be a dream 2800 lbs car
4.8 = $800
you'd still be better off with the 5.3. If you're really hard pressed to destroke, use a 4" bore block (Ls2, LQx) and a 5.3 crank.
#23
the 5.3 crank is the same as all the rest. the 4.8 and the ls7 are they only ones with drifferent cranks.
useing all stock 5.3 and 4.8 pistons is just a high compression 5.3.
#26
So if the 4.8, 5.3, and 6.0 all have the same bore just different stroke, does that mean if you wanted to make your 4.8 into a 6.0 just add crank, rod and pistons to the 4.8 block and you have the 6.0? I am sure the heads would have to be different right?
#27
lukn4trbl355
Oct 21, 2015 11:19 PM
lycominghunter
26
Sep 25, 2015 07:50 AM
