Boost questions
Old Dec 20, 2017 | 11:21 AM
Crysis450's Avatar
Originally Posted by turboal1
You will deff need a diff pump, just changing
to a stock 5.3 requires a pump change in a
Colorado.
And why is that
Old Dec 20, 2017 | 11:30 AM
BudRacing's Avatar
Originally Posted by Crysis450
And why is that
The volume demands that 3 additional cylinders require, I would imagine. The flexfuel pumps flow a little better due to the nature of volume required in E85 applications. Generally, if you're going for 450 whp+ you're going to need to upgrade the fuel pump.
Old Dec 24, 2017 | 10:07 AM
BT802's Avatar
10 Second Club
Your pump wont flow enough. Spend the $100 on a Walbro 450.
Old Jan 8, 2018 | 06:39 PM
Crysis450's Avatar
Another question what if i use both fuel pumps as in the colorados as a feed and the walbro 450
Old Jan 10, 2018 | 01:51 PM
BT802's Avatar
10 Second Club
For what reason? Just swap the 450 in and be done, it can support something like 750whp on pump gas and 600whp on e85 by itself. No need to complicate things even more IMO.
Old Jan 10, 2018 | 09:26 PM
Crysis450's Avatar
Oh just for a simple install but yah i wont be needing both ima need to fabricate another feed line
KySilverado
May 29, 2010 02:42 AM
Envelope Man
19
Apr 3, 2008 08:47 PM
viciousknid
Oct 7, 2007 04:03 AM
Spires
Aug 21, 2007 09:21 PM
desTRUCKtive
49
Feb 15, 2005 05:49 PM
