Boost questions
Old Dec 18, 2017 | 09:35 AM
Crysis450's Avatar
Default Boost questions
Hey there i had a couple questions im planing on putting a turbo on my 5.3 i already have the complete turbo kit and and injectors but, am i going to need a fuel pump? mine is rated 55-60 and i was going for around 8lbs
Old Dec 18, 2017 | 10:58 AM
FFDP's Avatar
A walbro 400 or 450 would support that power no problem on pump gas. Keep fuel pressure at or very close to 58psi and you are fine.
Old Dec 18, 2017 | 12:23 PM
Crysis450's Avatar
so wouldnt my fuel pump be ok its the stock colorado fuel pump
Old Dec 18, 2017 | 02:13 PM
FFDP's Avatar
I have no idea, you never said what you drive, what model, if it's flex fuel or not.
Any non flex fuel stock pump will not support a turbo setup that makes decent power.
Old Dec 18, 2017 | 02:58 PM
Crysis450's Avatar
Its just a 06 chevy colorado i look online and saw the fuel pump is rated at 55 psi, those wal 450 seems pretty solid and only around 100
Old Dec 18, 2017 | 03:08 PM
FFDP's Avatar
Yeah GM normally runs 55-60 or often just 58psi for a 4 bar fuel system. Most injectors are also rated at 4 bar (58psi).
What you need to really know is how much the pump can flow. A stock pump that only flows 150-180lph of fuel can't flow enough when you double the power of an engine while running a richer fuel mixture. That's why going to something like a 400 or 450lph pump is wanted, so there is plenty of fuel flow. What I can't tell you is wether or not you need to purchase an aftermarket fuel pressure regulator for your vehicle/setup.
Old Dec 18, 2017 | 10:24 PM
Crysis450's Avatar
Oh ok makes sense, i am runing the corvette fuel filter regulator
Old Dec 19, 2017 | 12:20 PM
turboal1's Avatar
Default Pump
Was the truck an I4 or an I5 to begin with ?
Colly's are not Flex Fuel. I would deff change
the pump.
Old Dec 19, 2017 | 10:46 PM
Crysis450's Avatar
It was a i5
Old Dec 20, 2017 | 11:10 AM
turboal1's Avatar
Default Pump
You will deff need a diff pump, just changing
to a stock 5.3 requires a pump change in a
Colorado.
