Boost questions
Hey there i had a couple questions im planing on putting a turbo on my 5.3 i already have the complete turbo kit and and injectors but, am i going to need a fuel pump? mine is rated 55-60 and i was going for around 8lbs
Yeah GM normally runs 55-60 or often just 58psi for a 4 bar fuel system. Most injectors are also rated at 4 bar (58psi).
What you need to really know is how much the pump can flow. A stock pump that only flows 150-180lph of fuel can't flow enough when you double the power of an engine while running a richer fuel mixture. That's why going to something like a 400 or 450lph pump is wanted, so there is plenty of fuel flow. What I can't tell you is wether or not you need to purchase an aftermarket fuel pressure regulator for your vehicle/setup.
