Boost Gauge Install
Old May 13, 2004 | 10:27 PM
Last Call's Avatar
TOTM: January 2007
Default Boost Gauge Install
I just received the Magnacharger Boost gauge. Which vacuum lines do you guys usually tap into? I don't even know if it matters. Is there anything I should do make the install easier? As far as the wires, just go into an accessory, right? It seems easy enough, just want to make sure. Thanks.
Old May 13, 2004 | 11:59 PM
BlownAlaskan's Avatar
There is a plastic tab on the side of the intake manifold that can be broken off. The remaining tube is the right size to connect a vaccum line to.
Old May 14, 2004 | 01:05 AM
BlownChevy's Avatar
blownerator
25 Year Member
Tap into the line that goes to your Fuel Pressure Regulator. There should be a metal tee included with the kit.
chopperloco
Jul 10, 2016 10:45 PM
thunder550
Oct 8, 2015 04:53 PM
Ls3silverado
Jul 31, 2015 04:22 PM
FlowmasterMufflers
Jul 22, 2015 01:29 PM
