Bogging at my 1-2 shift
Old Feb 14, 2005 | 10:17 PM
derek_silvy's Avatar
Default Bogging at my 1-2 shift
I tested my Auburn out today, and it did alright. I was out on the road in front of my house, which doesn't have the best of traction conditions. There is some light sand and dirt on the road (same as any public road), and the tires always get light sand (enough to make it slick) on them. Anyway, before my Auburn, I was running 7.3-7.4 0-60. Now I am cutting a best of 6.3, some 6.4, then some higher 6.Xs.
Anyway, every time it shifts into second gear, it kind of bogs. I think part f the problem is that it is breaking traction into the shift. Not nearly as bad as with the open diffy, but it does shift and throw it up (almost instanly) about 5mph..... I am thinking that the bogging is coming from the spinning and then catching.
I think with some launching practice I can cut the times down to 6.0-6.1, maybe lower.
If I could figure out why I am bogging, and fix it, I think I'ld be in good shape....
Advice?
Old Feb 14, 2005 | 10:21 PM
Kano's Avatar
TM maybe?
Old Feb 14, 2005 | 10:25 PM
Brian (of PCM4LESS) was suppose to have all of that removed.
Old Feb 15, 2005 | 01:48 AM
storm5.3's Avatar
13 Second Truck Club
I've got to go w/ TM too. Mine doesn't do it and I have a super hard shift w/ the TransGo, both billets, performance 1-2 accum. spring, pinless accum. pistons, and the stock stall. Even w/ 300 lbs. sitting over the axles (tool boxes, spare and ****) it doesn't do it, just lites 'em up and keeps pullin'...Zed
Old Feb 15, 2005 | 08:33 AM
Have you added TM already?
To me, adding TM back in is a band aid on a broken arm..... and I'm not 100% sure that the spinning is causing the bogging.
Blwn99x
Mar 24, 2023 11:14 AM
RustyD
May 23, 2016 07:04 PM
Wolftrk99
Dec 3, 2015 08:12 PM
Cammed4ever
Sep 30, 2015 03:38 PM
sTNT971
Sep 26, 2015 06:27 AM
