Blown three sets of collector gaskets.....
Old Aug 18, 2005 | 11:28 AM
F8L Z71's Avatar
Copper ones worked well for my buddy. Both of use had major sealing troubl with the AS&Ms.
Old Aug 18, 2005 | 01:46 PM
thunder550's Avatar
High on diesel fumes
OK thanks I just ordered a set of copper ones. Is there some kind of design flaw with the ASM's that keeps them from sealing well?
Old Aug 18, 2005 | 01:49 PM
goshawk23's Avatar
Truck addict
good deal on the copper ones. i have had no problems with them at all. i was blowing gaskets out of my cutout left and right. finally went with copper on that and my headers and have had zero problems.
Old Aug 18, 2005 | 04:44 PM
bluecajun5.3's Avatar
11 Second Truck Club
i use copper ones on my chevelle back home. haven't had a problem with them. they work fine even after reusing them
Old Aug 18, 2005 | 08:54 PM
Flyer's Avatar
I've not had a header yet (TOG's or the 3 bolt flanges on my PaceSetters) that sealed up good. I'm seriously thinking about those header buddie.s
Old Aug 18, 2005 | 09:17 PM
BigTex's Avatar
I went through several paper and metal gaskets until I tried the aluminum ones. My aluminum gaskets worked well until I installed the radix. At that point, temps and pressure made mine melt too. Copper worked better, but didn't seal up as tight.
I moved my ASMs to 3" ball / socket flanges and now have no problems. Much easier to work with and not even minor leaks.
Old Aug 18, 2005 | 09:36 PM
budhayes3's Avatar
PT's Slowest Truck
Did you use those header buddy's or did you fab your own?
Old Aug 18, 2005 | 10:41 PM
BigTex's Avatar
I bought a kit that had both sides. I cut off the existing 3 bolt flange, then expanded the header out to 3" diameter. Then I had to weld one side to the header and the other to the pipe.
Old Aug 19, 2005 | 12:05 AM
thunder550's Avatar
Wow...I hope I don't have to do that.
Old Aug 19, 2005 | 01:24 AM
Grey Silver's Avatar
11 Second Club
I run Ultra Seal gaskets and never have a problem.
